New noise when switching to macro
x
  • 1 year later...
Hi, I would like to know how did you solve the problem with click sound when switching to macro?
I have my leica 2 years, 3 month ago entire lens was replaced and now sometimes I hear strange click sound when switching to macro mode.
Thanks
I too am hearing a clicking sound when I go from regular to macro mode. Has anyone experienced this? The sound is single click when rotating the macro ring from standard to macro mode. It kind of sounds like something is binding up or when turning the ring into macro mode.
Please reply if you’re having this issue and more importantly what you did to fix it.
The click may be dependent on the temperature. For example, this morning the click was gone. The camera temperature was 74.4°. The macro ring does bind up a bit when moving from normal to macro but no click. When the click returns I will measure and report back.
My theory would go like this: Fluctuations in temperature causes high tolerance parts to become slightly out of tolerance thus causing the clicking sound.
Edited by hionhifi
Guest jvansmit
Do you notice any pattern to it happening?
no pattern as such....there's a marked resistance & click when I switch to macro if I haven't used it for a while. It disappears if I turn macron on/off 2-3 times, and then returns if macro is not used for a while
Yeah, that's literally the same problem I'm having. It concerns me. I'm worried about the long term durability of the camera because of this. What is your take?
Guest jvansmit
I've already had the lens assembly replaced once because the AF to manual focus detent didn't engage, and as well as not wanting to have another long delay while the camera goes back to Germany, my Q is out of warranty so I'll just have to live with it :(
  • 2 months later...
Hi,
I sent video with "click" sound to Leica customer service and they replied that it is definitly not normal. It seems that they already know about this lens issue. And it is not difficult to fix it. Don't know the price yet. But probably it will be free.
Guest jvansmit
Hi,
pls let us know how this works out :)
Guest jvansmit
I wouldn't send in my camera to Leica unless you could see the lick sound in the photo.
I had four different Leica Q cameras until now and they all made different sounds. Nothing to worry about.
Nothing to worry about? How about this quote from Leica ;)
"Necessary labour costs: Exchange focal length adjustment ring, exchange lettering ring/ classification, adjustment of all parts.
Necessary materials: Lens, complete.
Repair cost : HK$12,550 ($1,600)"
Leica will repair everything you give them to repair.
But if there is no real malfunction (optical or mechanical malfunction so that you can't switch the mode) and the only problem is different click sound when switching to macro, I see no reason for a service order.
Hi,
I don't know how load the click is but with mine if the camera is switched on there is a faint click at one end of the macro movement in either direction. That is not there when switched off and so I assume that the faint click is associated with some movement of a lens element, which is what one might expect.
I guess what you hear is the autofocus adjusting.
  • 1 month later...
I fiddled with mine this morning, and you are correct.  It only happens when the camera is turned on, regardless of whether or not the aperture is set to auto.  The sound coincides with the aperture being stopped down a bit.  I believe I read that, in macro mode, maximum aperture is f/2.8.
