Sensor Problem
Abhinava Goswami
I am using M9 from last 3 years but never had any problem but today I found that images capture by camera are split in two tone left side is ok but from right side is image is magenta in tone so I am wondering what could be the possible cause for this ,i.e camera is never dropped or hit by anything. How to fix it and where to send in Europe specially in Germany.Help is needed.
Sent from my iPad using Tapatalk
Agree, possibly needs new semsor but quite aome time ago an aquantances M8.2 started having images with magenta segments. Turned oit their SD card went bad or got corrupted. Once he switched cards and also brand, all was well. Worth a shot. Also try another battery in case curremt of batter is sligtly below spec. Nothing to loose by trying these two things first.
Dave (D&A)
  • 4 weeks later...
ciao a tutti ,
scusate se uso questo post ma la mia leica m-e ha un problema non so se al sensore .
scatto foto e compare una linea verticale sottile e bianca sempre allo stesso punto  !!!
cosa puo essere?
Hello to all ,
excuse me if I use this post but my leica-m and has a problem I do not know if the sensor.
Snap photos and you will see a thin vertical line and white at the same point !!!
what can it be?
