Leica M6 frame lines issues
Hi, so I recently got a M6 TTL with a .85 magnification.
Looking through it, I am able to see the 35mm frame lines that is very bright and bold.
However, when I move the preview lever to the right, I don't see other frame lines appearing.
I attached a 50mm Summicrion v1 rigid on the camera and I can see a very faint top line at times but it is not always very clear.
Does anyone know what can be the cause of this?
Thanks
  • 11 months later...
Jonathan,
Did you get the issue resolved?
I have just acquired an otherwise immaculate M6TTL with the same problem.
The vendor apparently hasn't used it much for a few years.
I often use a 50mm lens and I'm not experienced with an 8.5 viewfinder
so I think I need the frame.
Can't find anyone here in New Zealand to take on a repair, so looks like I may have to
send it to Germany.
I have no idea what kind of bill to expect if I do that, but I'm feeling the pain already...
Has anyone had an M6 or similar CLA'd by Leica Germany?
Or know of a reputable service technician in New Zealand ( or Australia )?
Any advice would be helpful!
Thanks
Jonathan,
send it to Germany.
Thanks
I highly recommend Peter: http://www.camerarepairs.com.au
But first try just moving it lots and lots, it might free up
