SonomaBear Posted July 26, 2016 Share #1 Posted July 26, 2016 Advertisement (gone after registration) This might be more of a Lightroom question. In testing the new 2.0 firmware (Amazing, Thank you Leica!). I explored using digital zoom. The image looks great at 50mm on the Q's LCD and even better in Lightroom. Even cropped in the camera, this is a great sensor. I set monochrome on Q (JPEG Saturation to Monochrome) which appears in LCD -- Lightroom displays the DNG's full color. No problem. But Lightroom displays the image in its 50mm crop. While nice, I might want to change the framing in post-production. Question is trying to restore the image back to the full frame 28mm image... Is this possible? Thank you everyone, this forum makes the best camera even better! Link to post Share on other sites More sharing options...
Advertisement Posted July 26, 2016 Posted July 26, 2016 Hi SonomaBear, Take a look here Digital Zoom, Lightroom CC, DNG Full Frame Recovery? . I'm sure you'll find what you were looking for!
Tom. Posted July 26, 2016 Share #2 Posted July 26, 2016 Use the crop function in Lightroom. You'll see the full image, cropped at 35/50mm equivalent. Only possible for DNG's. Link to post Share on other sites More sharing options...
SonomaBear Posted July 26, 2016 Author Share #3 Posted July 26, 2016 Use the crop function in Lightroom. You'll see the full image, cropped at 35/50mm equivalent. Only possible for DNG's. Thank you Tom, but I am trying to see the entire image. I can crop further in LR with develop/crop but I want to "undo" the crop from the Q's digital zoom. Link to post Share on other sites More sharing options...
Tom. Posted July 26, 2016 Share #4 Posted July 26, 2016 Strange. Directly after importing them in Lightroom, I only see the cropped version (if I used the crop-modes on the Q for that photo). But I can undo it by using the crop function in LR. After clicking on the crop tool, I see the full image (darkened) with a crop defined. I can use the 9 points around the crop and make it bigger and restore the full 28mm version. As said it works only with DNG's. They contain the full image, just with some added metadata (I think) for the crop-position that Lightroom will use. The JPG's are cropped in the camera and can't be undone. I use Lightroom 2015.6. Today I've upgraded to this version, but the one before (2015.5?) also worked. Link to post Share on other sites More sharing options...
SonomaBear Posted July 26, 2016 Author Share #5 Posted July 26, 2016 Strange. Directly after importing them in Lightroom, I only see the cropped version (if I used the crop-modes on the Q for that photo). But I can undo it by using the crop function in LR. After clicking on the crop tool, I see the full image (darkened) with a crop defined. I can use the 9 points around the crop and make it bigger and restore the full 28mm version. As said it works only with DNG's. They contain the full image, just with some added metadata (I think) for the crop-position that Lightroom will use. The JPG's are cropped in the camera and can't be undone. I use Lightroom 2015.6. Today I've upgraded to this version, but the one before (2015.5?) also worked. You are my hero! Yes indeed, I did not try the tool because I've only ever used it to reduce the view, not expand it to full frame. This will allow me to shoot with my eye concentrating on the inner 35/50mm view, see the things happening outside the area of concentration, then capture at the perfect moment. Later in my office, I can "re-crop" or "un-crop" to my eye's delight! Link to post Share on other sites More sharing options...
microview Posted July 27, 2016 Share #6 Posted July 27, 2016 I think you can move the crop rectangle around in the full DNG image, thus recomposing still to a crop ratio. Link to post Share on other sites More sharing options...
Guest Posted July 31, 2016 Share #7 Posted July 31, 2016 Advertisement (gone after registration) I see the full image (darkened) with a crop defined. I can use the 9 points around the crop and make it bigger and restore the full 28mm version. No need to pull the points if you want full image just hit the restore button at the bottom of the crop tool drop down box. Bob Link to post Share on other sites More sharing options...
