su25 Posted July 26, 2016 Share #1 Posted July 26, 2016 Advertisement (gone after registration) I find that standard jpg settings on SL are a good starting point for tweaking RAW files in LR. Any idea how I can replicate those settings in LR? For some lenses, I find that the embedded colour profile in LR/RAW is better than that in jpg, while luminosity values of jpg is better. In this case I use PS to apply image to a layer copy with blend mode as luminosity. While for certain indoor light conditions, I find the jpg colours are better than embedded, while the luminosity values are better in LR/RAW. In this case I use PS to apply image to a layer copy with blend mode as colour. Therefore, I would like to have the jpg settings applied to RAW images while importing to LR, and then post process. Is this possible? Link to post Share on other sites More sharing options...
Advertisement Posted July 26, 2016 Posted July 26, 2016 Hi su25, Take a look here Replicating jpg settings of SL in LR. I'm sure you'll find what you were looking for!
tobey bilek Posted July 27, 2016 Share #2 Posted July 27, 2016 Use a color checker, Get the raw WB to match the JPeG, Apply a tone curve to raw so white to black squares MEASURE the same. now get the RGB squares measured individual values to match. Save as preset. Tell ACR or LR to aways open files from that camera serial number using that preset. Link to post Share on other sites More sharing options...
MRJohn Posted August 20, 2016 Share #3 Posted August 20, 2016 Use a color checker, Get the raw WB to match the JPeG, Apply a tone curve to raw so white to black squares MEASURE the same. now get the RGB squares measured individual values to match. Save as preset. Tell ACR or LR to aways open files from that camera serial number using that preset. Are you aware of a set by step manual with screenshots for this strategy, or could you support your post with a couple of screenshots? I am not good enough in Lightroom to fully understand from what you write what to do but have the same question as su25. Many thanks in advance. Link to post Share on other sites More sharing options...
