lm_user Posted May 3, 2016 Share #1 Posted May 3, 2016 Advertisement (gone after registration) Many have touted the flatfield correction in LR. Can this also be used in ACR? I do not have LR Link to post Share on other sites More sharing options...
Advertisement Posted May 3, 2016 Posted May 3, 2016 Hi lm_user, Take a look here Flatfield correction in ACR?. I'm sure you'll find what you were looking for!
zeitz Posted May 3, 2016 Share #2 Posted May 3, 2016 The Develop Module in LR is ACR, and it is the same as ACR in Photoshop CC with the controls rearranged, as far as I can tell. I looked at the latest versions of both software, updated last week; this statement may not be true for old versions. I'm not exactly sure what you mean by "flatfield correction". Do you mean pincushion/barrel correction? ACR can correct these. But real transforms, such as to correct the keystone effect, are only in Photoshop CC. (I could always be wrong about transforms in LR as I don't use LR.) Do you mean vignetting? ACR can correct these. Perhaps you mean dehaze to improve images that appear flat in color due to haze. ACR has a tool/effect for dehaze. I don't know of any software to correct for field curvature - surface of sharp focus being spherical rather than flat, an effect often see in lenses of achromat design. In Photoshop CC (not in ACR) you can combine images taken at different focus settings to produce artificial depth of field. If I've missed a capability in Photoshop, we'd both like to know. Link to post Share on other sites More sharing options...
ramarren Posted May 3, 2016 Share #3 Posted May 3, 2016 You can only use the Adobe DNG Flatfield Correction plug-in with Lightroom. The flatfield correction plugin is designed to correct image shading (the tendency of the image to be, say, magenta on one side and green on the other) that occurs with some lenses, usually symmetric short focal lengths. BTW, LR does allow pincushion/barrel distortion correction, keystone correction, as well as a variety of other lens corrections. There are many plug-ins for LR as well that can accommodate even more image processing needs and situations. Link to post Share on other sites More sharing options...
lm_user Posted May 3, 2016 Author Share #4 Posted May 3, 2016 Thank you both Zeitz - I was specifically referring to the cornerfix replacement Ramaren described. Too bad the plugin cannot be used with ACR. Link to post Share on other sites More sharing options...
zeitz Posted May 3, 2016 Share #5 Posted May 3, 2016 Thanks, Ramaren. I'll look for keystone. Lens profiles in ACR are available for most lenses including CV 15mm. Link to post Share on other sites More sharing options...
