mbc 1944 Posted June 25, 2016 Share #41 Posted June 25, 2016 Advertisement (gone after registration) To the list for the firmware: I find it almost incomprehensible that the right side controller button requires a right-side click to save a setting, instead of the central push button, which is used on every other camera I have seen with such a control. I just got the Q and spent 20 minutes trying to save settings by pressing the central button and each time was redirected to the menu. I actually had to go to the instruction manual! Link to post Share on other sites More sharing options...
Advertisement Posted June 25, 2016 Posted June 25, 2016 Hi mbc 1944, Take a look here LEICA Q FIRMWARE UPDATE 2.0??? WISH LIST! . I'm sure you'll find what you were looking for!
nick h Posted June 28, 2016 Share #42 Posted June 28, 2016 One more wish...Can we get a Q with a 75 mm lens? It could be called the QT (for tele ; ) ). That would be great combination with the 28mm Q... Link to post Share on other sites More sharing options...
Hektor6644 Posted June 30, 2016 Share #43 Posted June 30, 2016 I'd be interested to find our what prime 42mm lens you have been using as favourite on other full frame bodies. Hi: For a DX sensor my favorite focal length is 28mm, which translate to 42mm in 35mm or FF format. For my D5500 - IR, I have the Nikon 28mm f/1.8G and for my X-T10 I have the Fujinon 27mm f/2.8. In addition for my D750, I have the Tamron 45mm f/1.8 VC. It is not 42mm but close enough. Hektor Link to post Share on other sites More sharing options...
Hektor6644 Posted June 30, 2016 Share #44 Posted June 30, 2016 Link to post Share on other sites More sharing options...
Peyton Hoge Posted June 30, 2016 Share #45 Posted June 30, 2016 To the list for the firmware: I find it almost incomprehensible that the right side controller button requires a right-side click to save a setting, instead of the central push button, which is used on every other camera I have seen with such a control. I just got the Q and spent 20 minutes trying to save settings by pressing the central button and each time was redirected to the menu. I actually had to go to the instruction manual! To save a menu setting, you push the center button of the control button. Link to post Share on other sites More sharing options...
Herve5 Posted July 3, 2016 Share #46 Posted July 3, 2016 Birding mode and the remote. While this feature probably regards a minority of users, it happens the present "birding mode" would be very fine to be used along with a tablet, so as to show the birds (or... the planets, at night) to a larger audience while one is dealing with aiming and focussing on the cam and scope. This alas won't work at all, because once the Q connects to the tablet, it switches off the rear view. And then, you cannot adjust quickly, dfinitely. These things barely work for picturing stars, because you have plenty of time and are motivated by a fully remote trigger without any vibration -but this just does not work with moving birds... My take is, there definitely is a significant opportunity to enhance things, and by the way to show the Q in direct action, through allowing both the rear panel AND the remote control at the same time. I understand it'd be a concern to get commanding from both sides (the tablet + the rear panel) : you don't need to implement that, just showing the image on the rear panel, plus maybe some "remote-controlled" sign will be enough. Link to post Share on other sites More sharing options...
Adalsteinn S.H. Posted July 10, 2016 Share #47 Posted July 10, 2016 Advertisement (gone after registration) Am a little pissed when the histogram disappears when I toggle the exposure compensation wheel. Would prefer to see the histogram change live while the toggle the wheel. Let's hope for the best when the new firmware comes. Link to post Share on other sites More sharing options...
millsart Posted July 11, 2016 Share #48 Posted July 11, 2016 I second the 75mm version idea I've gone through the Lumix GX8 with 42.5 f1.2, the Sigma DP3m, the Sony A6300 with 50mm f1.8 and the Fuji XPro2 with 56mm f1.2 for my second tele body, because I always feel that I can't live with only the Q, yet none of those cameras/systems is as fun to shoot, or as well designed as the Q With a short tele version of the Q (and cropping for 90/135), in addition to my current Q (and occasional stitch pano's when I need something really wide for landscapes) I could cover probably 95% of my shooting needs, with a very easy to travel with 2 body solution sharing the same design, interface, battery etc. Pricey kit for sure, but it would be a cracker Link to post Share on other sites More sharing options...
Guest Posted July 11, 2016 Share #49 Posted July 11, 2016 I wouldn't be at all surprised if we'll not see another firmware upgrade for the Q, leastways not this year anyway. Leica has it's hands full trying the make the SL system "professionally" more attractive in terms of an expansion of the present dedicated SL lens options, and then of course there's the continuing rumours of a "new M" announcement said to be due in September. Leica has never been good at timely product firmware upgrades, when forced they will quickly address some things with new systems as they did with the SL but to add features or firmware modifications to an existing camera system like the Q that now been out in the wild for a couple of years, ( is it two or more years now? ), I believe isn't going to happen. I think for Leica the Q has been "good enough", a good experiment that's paid off very nicely for them and has pointed a developmental direction that may expand down the road, but any further noodling with the firmware I can't see happening which is a pity because for me just a few changes would really make the camera damn nigh perfect…….. Hopefully I'm wrong……... Link to post Share on other sites More sharing options...
SonomaBear Posted July 11, 2016 Share #50 Posted July 11, 2016 WLAN in Client mode should remember the password for WiFi networks. and I am still trying to sort out the NFC for my iPhone's usage... Link to post Share on other sites More sharing options...
marchyman Posted July 11, 2016 Share #51 Posted July 11, 2016 and I am still trying to sort out the NFC for my iPhone's usage... There's nothing to sort out. Apple does not allow access to iPhone NFC to outside developers. It only works with Apple Pay. That may change in the future. Link to post Share on other sites More sharing options...
40mm f/2 Posted July 12, 2016 Share #52 Posted July 12, 2016 I second the 75mm version idea I've gone through the Lumix GX8 with 42.5 f1.2, the Sigma DP3m, the Sony A6300 with 50mm f1.8 and the Fuji XPro2 with 56mm f1.2 for my second tele body, because I always feel that I can't live with only the Q, yet none of those cameras/systems is as fun to shoot, or as well designed as the Q With a short tele version of the Q (and cropping for 90/135), in addition to my current Q (and occasional stitch pano's when I need something really wide for landscapes) I could cover probably 95% of my shooting needs, with a very easy to travel with 2 body solution sharing the same design, interface, battery etc. Pricey kit for sure, but it would be a cracker I also have a Sigma DP3m and i like the 75mm equivalent and almost macro ability but I really hate to use it: too slow, no VF, basically useless display in bright light and dynamic range too limited but once in a while it allows me to make some good pictures. So something so easy to use as the Q with 75mm would be great (I had a 75mm Summilux and like it too except for its weight), too bad one can not get that through firmware update. Link to post Share on other sites More sharing options...
matlep Posted July 21, 2016 Share #53 Posted July 21, 2016 Seeing some light in the end of the tunnel: http://leicarumors.com/2016/07/21/leica-q-firmware-update-version-2-0-to-be-released-on-july-26th.aspx/ Link to post Share on other sites More sharing options...
