chris24turner Posted March 21, 2016 Share #1 Posted March 21, 2016 Advertisement (gone after registration) Is anyone aware of a bug (known/reported or otherwise) relating to use of the softkeys? In my SL (latest firmware installed) having assigned short-cuts to frequently used settings, I have noticed that the top-left softkey does not display the selected shortcut option in the Viewfinder. It does display all four shortcuts on the LCD screen and the buttons in bottom-left, top-right and bottom-right all display in the EVF with no problem but the Top-Left assigned shortcut does not display in the viewfinder at all. Link to post Share on other sites More sharing options...
Advertisement Posted March 21, 2016 Posted March 21, 2016 Hi chris24turner, Take a look here Firmware issue/bug relating to soft-key. I'm sure you'll find what you were looking for!
AlanJW Posted March 21, 2016 Share #2 Posted March 21, 2016 Give it a longer press maybe. Mine is set to ISO and works that way. It takes some getting used to the long press/short press way the buttons work. Link to post Share on other sites More sharing options...
Cliff S Posted March 21, 2016 Share #3 Posted March 21, 2016 you need to enable it in the settings. It defaults to off as it can easily be accidentally triggered. There is a setting to enable in in the viewfinder. Link to post Share on other sites More sharing options...
ramarren Posted March 21, 2016 Share #4 Posted March 21, 2016 Setup > Customize Control > Menu Access in EVF is disabled by default. Enable it and you will be able to use short and long press functions with the Upper Left button while using the EVF. Link to post Share on other sites More sharing options...
chris24turner Posted March 22, 2016 Author Share #5 Posted March 22, 2016 Setup > Customize Control > Menu Access in EVF is disabled by default. Enable it and you will be able to use short and long press functions with the Upper Left button while using the EVF. Thank you @ramarren. That was indeed the 'problem' I think we'll put it down to 'operator error' Really appreciate the help. Thanks to the other guys also, who commented. Case closed! Link to post Share on other sites More sharing options...
