Nice series ! Thank you !
How about some small, fast flying birds ... :) :) ;-) ??
Gesendet von meinem iPad mit Tapatalk
Not a bird but certainly fast flying. A Canadair fire bomber flying boat above my house at an estimated 150kts, with 90-280. Unfortunately the small post size here prevents you seeing just how sharp the combination of the 90-280 and SL really are. When you blow the photo up, you can easily read the small print on the tail (says Canadair - CL415)
Wilson
Edited by wlaidlaw
Wilson
Thanks for the big bird foto !
I am just asking myself whether the SL / 90-280 combo will be fast (accurate) enough for small, fast flight models.
Maybe I will need to rent a 90-280 and have to find out be myself ...
this is all I have with the 90-280 .... (all my other robins where with the 280/2.8 R) ...... they stopped momentarily and inconsistently on this post before flying to the nest .... catching a shot was very difficult
Edited by thighslapper
  • Like 17
and these haven't learnt to fly yet .....
I also took a selection of these paddling about ...... and they move very quickly and a rather randomly ..... tracking worked very well and all the mobile shots were in focus ..... even when they momentarily went behind reeds .... the only issue being not having a fast enough shutter speed for some.
Were you using AF? Prefocused or single point AFS? Your subject must be less than 5m away?
AFs - 3m... spot on where I estimated the head to be. Sat for ages with a remote release ..... the main issue was ME not being quick enough .....  :unsure:
It was not visible when I viewed the pics even after LR in my smaller screen Mac Book Air, therefore I could not answer your question.
I had seen banding appearing in images captured by my M240 @ ISC 3200 in low light having clearly visible banding across 1/5 of the image in the past. Comparing them, the banding I see on my SL's ISO 12500 image is mild.
Are you on fw 2.0? I had banding on 1.x but it's essentially completely resolved with 2.x. Mind you I don't think I've ever taken a photo at ISO 12500. (that's not a criticism. just a personal observation).
Gordon
Gordon
When the photo was taken, my SL was on FW2.0. I'm not really a bird shooter but rather I was testing my SL pushing ISO and AF to the limit so that I know the limitations when I start enjoy shooting the camera after I get familiar with it.
I find a 300mm lens' DOF at f/2.8 to be too skinny to be useful so one stop faster means bigger, heavier and costlier.  No advantage for me.
I am not interested in AF, so for me the amazing AF invites Mr. Murphy's law.
The Sony's sensor stabilization doesn't add any air/glass surfaces, and doesn't de-center any glass when working.  No need to discuss resolution or chromatic aberration, the 280/4 is exemplary.  I don't see any advantage for the Canon.
I have the EF 300 f/2.8 MkII, and use it on a 1DX for sports photography. Shooting indoor velodromes, it never gets off 2.8, and I'm generally running at ISO 3200 at relatively well-lit tracks. The AF combo of the 1DX with this lens is phenomenal. I have not seen any CA present in many thousands of shots with this lens. The lens easily out-resolves the 36MP A7R that I sometimes use it on, too.
I can't compare it with the 280/4, except that f/4 would be a no-go maximum aperture for what I do.
I have the EF 300 f/2.8 MkII, and use it on a 1DX for sports photography. Shooting indoor velodromes, it never gets off 2.8, and I'm generally running at ISO 3200 at relatively well-lit tracks. The AF combo of the 1DX with this lens is phenomenal. I have not seen any CA present in many thousands of shots with this lens. The lens easily out-resolves the 36MP A7R that I sometimes use it on, too. I have used it on my M246 with EVF, which can also make for some nice shots.
Hi "Thighslapper"!
Very nice photos.
I may get SL Apo 90-280 ASPH (just concern its weight and size) to combo with my Leica SL and SL 24-90 ASPH.
Have a nice day!
Thanks!
I cannot clearly see if the 270 is from the original patent or just a typo of the website designer. Can you ?
Anyway, designing a lens and producing it are two different shoes. Why should it not be designed by Panasonic ? I think they have a rich experience in  "wide-range" zooms (for film/video cameras). Maybe it was designed by Leica, but Panasonic owns a stake in Leica and the right to file the patent ? (just speculating, I don't know)   Is this a wordwide patent, or just for Japan ?
But probably Panasonic could not produce (and sell) such an expensive lens - with Leica many buyers are more price-tolerant.
With a japanese producer I am usually off the bandwagon if the lens takes a long time to get delivered and has an extraordinary high price tag.
The price (and quality) probably also depends on the types of glass used. Is this also visible in the patent ?
Surely Leica's 90-280mm lens'patent would have been registered c.2 to 3 years ago. The Panasonic 90-270mm might be a totally new lens and for use with their rumoured FF organic sensor. The 90-270mm specification does not necessarily mean that it's the existing Leica 90-280mm.
dunk
That is quite strange.  Why would Panasonic patent a 90-280 full frame lens when they don't make any full frame lenses or full frame cameras?  And it has 23 elements, the same number as the Leica 90-280 lens.
Edited by zlatkob
It certainly looks to be the same as the Leica, to my untrained eye. I would have though that if it is the same lens that a patent would have been registered before it was produced, if indeed Panasonic make the 90-280. I'm sure Leica said the SL system was not a collaboration with Panasonic but maybe the lenses are (as rramen said in another thread). If that's the case are Panasonic considering their own body that will use the L lens mount? No that'd be interesting.
Gordon
It's identical to the 90-280 construction shown on Leica's website.
