jevidon Posted January 30, 2016 Share #1 Â Posted January 30, 2016 Advertisement (gone after registration) I understood that there was to be a T adapter for the R lenses as well. Any information on this? Link to post Share on other sites More sharing options...
Advertisement Posted January 30, 2016 Posted January 30, 2016 Hi jevidon, Take a look here T lens adapter for Leica R mount lenses. I'm sure you'll find what you were looking for!
gbealnz Posted January 31, 2016 Share #2 Â Posted January 31, 2016 Not that I've heard. In my case, I use the genuine M-T adapter. Then an EOS to M, with an R to EOS adapter. Dogs breakfast? You bet, but it's what I have, and it works. Gary Link to post Share on other sites More sharing options...
pop Posted January 31, 2016 Share #3 Â Posted January 31, 2016 There will be an R to SL adapter. I would presume that this would work very well on a T as well, when and if. Link to post Share on other sites More sharing options...
AndreasAM Posted January 31, 2016 Share #4  Posted January 31, 2016 Not that I've heard. In my case, I use the genuine M-T adapter. Then an EOS to M, with an R to EOS adapter. Dogs breakfast? You bet, but it's what I have, and it works. Gary  Gary,  You are aware that there is a M-R adapter from Leica and Novoflex as well?  No need for using two EOS adapters to get from M to R.  I use the M-T and M-R adapters from Leica frequently with much succes as many others on the forum. Link to post Share on other sites More sharing options...
MichaelU Posted January 31, 2016 Share #5 Â Posted January 31, 2016 There is a Novoflex T to R Adapter available. Works very welk for me. Link to post Share on other sites More sharing options...
gbealnz Posted January 31, 2016 Share #6 Â Posted January 31, 2016 Gary, Â You are aware that there is a M-R adapter from Leica and Novoflex as well? Â No need for using two EOS adapters to get from M to R. Â I use the M-T and M-R adapters from Leica frequently with much succes as many others on the forum. Andreas, yes, I was aware of that, two reasons mean I use what I have. Frugality, and functionality. The EOS-LM adapter I have is "cost effective", cheap in other works, and it works. The reason I use EOS (and I don't even have an EOS camera), is that most of my astro fittings are standardised for EOS. Most lenses fit this mount, obviously by way of adapters, but most all fit. So I can mount a Contax lens (C/Y) on the camera via a cheap and simple additional adapter. Ditto with Nikkors, Pentx whatever, and so on. And so it is with my scope fittings, most of my fittings relate to the EOS mount. Gary Link to post Share on other sites More sharing options...
AndreasAM Posted January 31, 2016 Share #7 Â Posted January 31, 2016 Advertisement (gone after registration) Sounds like logical explanation and thoughtful way of acquiring stuff! Â With this combination you only miss the use of the left dial for zoomfocus, that's what you win in functionality with the Leica combination. it is very useful and I believe you use your M-lenses on the T. Â Regards, Link to post Share on other sites More sharing options...
gbealnz Posted January 31, 2016 Share #8 Â Posted January 31, 2016 Nope, the left dial works. Hmmmmmm, now you have me thinking, I know it works with the M lenses, but I also use the genuine M-T adapter. Pretty sure it does work though, I recall using the left dial to get either 3x or 6x when using the T on the back of the telescopes. Hmmmm, I will have to go check this, with my 50mm Summicron R. I'll be back, as Arnie would say. Gary Link to post Share on other sites More sharing options...
AndreasAM Posted January 31, 2016 Share #9  Posted January 31, 2016 You could be right,  Gary  Because you fitted the  Leica M-T adapter first, which has the electronic contacts. That is enough to engage it. My mistake.  Now if they would also incorporate the lens profiles for the M and R lenses in the firmware, like with the SL, then you need the M-R or T-R adapter from Leica. I know it will come some day for the T! Link to post Share on other sites More sharing options...
chrisfugiel Posted April 14, 2016 Share #10 Â Posted April 14, 2016 There is a Novoflex T to R Adapter available. Works very welk for me. Can tell me where to buy? Link to post Share on other sites More sharing options...
jdlaing Posted April 14, 2016 Share #11 Â Posted April 14, 2016 Can tell me where to buy? Â http://www.bhphotovideo.com/bnh/controller/home?O=&sku=1103370&gclid=CPLVx5-OjcwCFRCOaQodkSwInA&is=REG&ap=y&m=Y&c3api=1876%2C92051677682%2C&A=details&Q= Link to post Share on other sites More sharing options...
MichaelU Posted April 14, 2016 Share #12 Â Posted April 14, 2016 Can tell me where to buy? I got my one on eBay. Link to post Share on other sites More sharing options...
Guest Posted April 22, 2016 Share #13 Â Posted April 22, 2016 Leica Store Zurich. Leica Shop Vienna. Link to post Share on other sites More sharing options...
Kyros Moutsouris Posted July 14, 2016 Share #14 Â Posted July 14, 2016 Will this adapter need a software update? https://uk.leica-camera.com/Photography/Leica-SL/Lenses/R-ADAPTER-L Â Â Sent from my iPad using Tapatalk Link to post Share on other sites More sharing options...
