post process: Process 2010 or 2012 for MM 246
Akaki
Dear members, what is your experience with post process in LR 6?
Which process 2012 or 2010 is better for you and why.
For me personaly 2012 works better with MM 246, but some artificial details comes out, not always.
2010 works works also great but has some limits for me, it's more natural but with limits.
what is your experience?
thank you
koka
Use process 2012 for every new file to be edited for any camera.  Process versions are not camera-specific.
Process 2010 and process 2003 are meant to be used with images that already have been edited  before, using those  older processes in case you want to retain your edits, as those edits may be lost when using a newer process.
Use Process 2012 for all new files and for those files you want to postprocess from scratch.
https://helpx.adobe.com/lightroom/kb/import-presets-lightroom-3-lightroom.html
https://helpx.adobe.com/creative-suite/using/process-versions.html
Personally I always use the newest process version even for older files, I find that the results are always better than before. (possibly not just because of the new process version, but due to creeping up the learning curve over time as well :unsure: )
I have always used the latest process that a software has for any camera, I think it would make matters to complicated working with different processes and there are plenty enough of tools and methods in todays post-processing software for me to adjust my images the way I want.
i always use the latest, but there are folks like Thorsten Overgaard, who routinely writes about his preference for older LR controls.  He doesn't switch around; he just prefers the old iteration. There are technical improvements with later versions, but there's no law when it comes to creative processes.
For a more practical, user based summary of the potential benefits of process 2012, this old article at LuLa by Charles Cramer is informative...
https://luminous-landscape.com/tonal-adjustments-in-the-age-of-lightroom-4/
Jeff
Jeff S
Thank you.
I was inspired by Thorsten Overgaard and many details was logical and help me a lot in first steps with monochrome, but then I find my self to much in frames and I start make different settings include 2012. Personally for this moment I am sure the 2012 is more adapted to MM 246 then 2010. It's personally for sure i don't make deep research. But I am spend less time with 2012 then 2010 to get what I want.
I've played with both and have pretty consistently stuck with 2012.  The "Fill Light" slider in process 2010 is a little easier for me to understand, but in the end I'm almost always happier with my results when using 2012.
This is the great thing about Lightroom's non-destructive nature.  You're free to play around with all of this stuff to your heart's content without consequences other than lost time.
I prefer the 2010 for M9 and M240 files and try to use it for SL and Q as well. On the M246 I tried both and stuck with 2010 as the most natural look.
The fill light is more extreme (or simply more fill light) in the 2010 but in many ways I think you should expect that new sensors are tuned for the 2012 Process. But I consistently find the 2012 to artificial/plastic for me and stay with 2010.
What I recommend is what I do myself: From time to time I do a test round and make a decision that I follow. I can't go back and forth all the time, so I decide on a workflow I follow. And then I will test again six months later or whenever I feel it is necessary; and then I follow that decision. Same with Capture One that I consistently have tested whenever they made a new version. I feel that at some point this might suit me better; but not so far. They might get there and I think that Lightroom has to end or be reprogrammed at some point, so someone might take over the lead.
I also keep an eye out for Phocus (from Hasselblad) and Sinar editing software if they start supporting Leica models.
If we had the time, we could treat each file individually to the best result, but with the amount of pictures we shoot (and how tiresome it is to sit by a computer), speed is of essence. So that means deciding on a tool and using it to its best. But also review ones decisions and workflow from time to time.
First of all, thank you Thorsten for your informative and inspiring work at your site.
I like the simple approach used in the article about M9 and B&W, http://www.overgaard.dk/leica-M9-digital-rangefinder-camera-page-16.html
Since I  have always used process 2012 I find it tricky to achieve the same outcome as shown in the video, are there some understandable links between the 2010 sliders and 2012 sliders in the basic panel?
Going back and forth between the processes I notice that a 2010 slider affect several of the 2012 sliders in the same time?
Are all changes from process 2010 to 2012 related to the Basic section or are there further changes?
I Perceive that my DNG pictures from the Q looks more "washed out" in 2012 than in 2010 with default settings
/Niklas
process 2010 -
Process 2012
Either of those could be made to look a hundred different ways.  For me, 2012 process provides more tools to get there and refine.  Thorsten likes the fact that he doesn't have to do much to the 2010 initial rendering to get the 'look' he wants.  My intent, on the other hand, is to spend time with every photo I make that is print worthy, and the effort and time is worth it if the image warrants.  In addition, one can alway make pre-sets to save time.  Different strokes...
Jeff
Phocus does support Leica files but unfortunately I have not been able to use Phocus Mobile without the attached "server" (iMac) on my iPad yet. So stand-alone in the field is not possible without having a portable at hand.
