56 minutes ago, farnz said:
@Andy_Shields
Voigtlander 10mm f/5.6 at or near minimum focus difference with M10.  The Black Country Living Museum near Dudley in the West Midlands.
The natural depth of focus of a 10 mm lens is very deep so precise focussing wide open (at f/5.6) isn't often needed.  Appropriate perspective correction was manually applied in PSCS6.  It's important to get the camera level and square-on to the subject or 'key-stoning' takes over very quickly.  The front element was something like 2 cm from the table edge in this picture; it's quite a small room and I could shake hands with the subject while holding the camera.
Pete.
Thank you, Pete. I appreciate you sharing the photo as well as your advice. I shoot a 16/8 Hologon often and even with that relatively telephoto lens (😁) I've come to learn the value of a perfectly level shot. I use the Frankenfinder on my film M's and I've found that its bubble level is worth its obnoxious size. Thanks again!
x
Hofje De Armen de Poth, Amersfoort NL (SL2-S + Sigma 14-24mm F2.8 DG DN | Art 14 mm)
vor 6 Stunden schrieb Andy_Shields:
I'd really like to own this 10mm one day. Do you have any shots made at it's minimum focusing distance that you can share? My biggest concern is that even at mfd foreground subjects will be pushed out too far. Thanks!
Thanks to Pete to jump in here. I'm afraid I never used it at the minimum focusing distance yet. It's such an extreme lens that I use it only rarely. You have to be rather careful to keep it straight and only few subjects are suitable for it.
Here one with some close stuff in the foreground. Maybe less than 1 m away. But I guess I might have focused the lens to about 2 m or even further and it is stopped down at least two f-stops.
  • Thanks 2
Mostar 19 mm: SL2-S + Sigma 14-24mm F2.8 DG DN | Art
Altes Rathaus, Zutphen NL 18 mm: SL2-S + Sigma 14-24mm F2.8 DG DN | Art
Altes Rathaus, Zutphen NL 14 mm: SL2-S + Sigma 14-24mm F2.8 DG DN | Art
Alte Bornhof, Zutphen NL 19 mm: SL2-S + Sigma 14-24mm F2.8 DG DN | Art
Korenmolen De Hoop, Gorinchem NL 17mm:  SL2-S + Sigma 14-24mm F2.8 DG DN | Art
Gorinchem NL 15mm:  SL2-S + Sigma 14-24mm F2.8 DG DN | Art
Edited by jannes
Krimpen aan de IJssel NL 16 mm: SL2-S + Sigma 14-24mm F2.8 DG DN | Art
Bibliotheek in Broederenklooster, Zutphen NL 14 mm: SL2-S + Sigma 14-24mm F2.8 DG DN | Art
Hologon 16mm 8.0 on Leica M6
Kodak Gold 200 (ECN-2 processing by Silbersalz35),
B&W conversion Edited by BastianK
vor 4 Stunden schrieb BastianK:
B&W conversion
Great composition! Would even have been better if you had used an b&w film.
Btw: is Silbersalz now also developing conventional C-41 color films?
Gotta love the sem…contrast galore.  M11 21mm sem.
