M Teleconverter?
vladik
Dear Leica users, I am not sure if this topic was ever discussed before. So, now that we have a Live View on some Leica camera bodies it would be possible to use teleconverters (I can hear roar of disapproval) with some lenses. I use to use a 1.4 teleconverter with Nikon lenses without any visible image quality degradation. Further question, would teleconverter affect image quality more than crop to the same field of view in post processing (I think not)? My personal wish would be for a 1.5 teleconverter for my 2.0/75 APO Summicron making it into nice 112mm lens.
Thank you for your reply Jaap, but I will pass on Komura T.C., as it would not give me image quality that I would be happy with and a decent modern one is non-existent. After fair bit of research I will get a Zeiss 2.0/135 Sonnar in Nikon mount and a Novoflex adapter for my M. Regards, Vlad.
I have a Komura, in fact I've had several.  The rangefinder coupling on all of them was iffy at best, definitely not trustable with a longer lens or wider aperture or close distance.  The one I have now had the rangefinder coupling removed and I got it for $25.  Used to use it mainly on a Visoflex as a macro converter, otherwise I either had to pre-focus the lens without the converter first, or just use it at infinity.  I haven't tried it with the M240 and EVF, but optically other than for macro and stopped down, it was never anything to write home about.  Plus it costs 2 stops of light, so firm support is a must.  I find cropping to be as good if not better than that converter.
... , of all the converters I ever saw only the Leica Apo ones managed to convince me. ...
... . The rangefinder coupling on all of them was iffy at best, definitely not trustable with a longer lens or wider aperture or close distance.  The one I have now had the rangefinder coupling removed.
... .  I find cropping to be as good if not better than that converter.
This brought me to the following result:  Modification for M: L. Apo Extender-M #11
A cropped picture is not quite as good as the optical solution. A 'small sensor' with similar resolution is a better (real) alternative.
Thorsten (;-)
