bideford Posted November 9, 2015 Share #1 Posted November 9, 2015 Advertisement (gone after registration) Looking for a 40mm UV-IR filter for Canon 50mm f/1.8 and 35mm f/2 lenses (I know I could use step up rings to get to a larger diameter but would prefer not to). There are a couple of £20 options on the bay sold for Fuji X10 (I do not think I am allowed to put the link up here - but they are easily found) - one of them is branded as a Rocolax. Anyone any views - should they work ok? - notwithstanding the usual lens is only as good as your last glass etc.. Will use the M8/Canon mainly for B&W (without UV-IR) but this would give an easy colour option when required. James Link to post Share on other sites More sharing options...
Advertisement Posted November 9, 2015 Posted November 9, 2015 Hi bideford, Take a look here 40mm UV-IR cut filter. I'm sure you'll find what you were looking for!
jdlaing Posted November 9, 2015 Share #2 Posted November 9, 2015 http://www.aliexpress.com/item/40-mm-40mm-Optical-UV-IR-Cut-Infrared-Lens-Filter-for-Canon-nikon-pentax-sony/32255109549.html Link to post Share on other sites More sharing options...
david strachan Posted November 9, 2015 Share #3 Posted November 9, 2015 I use a Rocolax UV-IR on my Canon 35mm f2 which has a 40mm filter thread. Works fine. And the threads take a lens hood as well. Take them off at night, not needed anyway, because they cause some pretty wild flare spots. cheers Dave S Link to post Share on other sites More sharing options...
bideford Posted November 9, 2015 Author Share #4 Posted November 9, 2015 I use a Rocolax UV-IR on my Canon 35mm f2 which has a 40mm filter thread. Works fine. And the threads take a lens hood as well. Take them off at night, not needed anyway, because they cause some pretty wild flare spots. cheers Dave S Ordered one - thanks! Link to post Share on other sites More sharing options...
