Leica Q and the UV/IR filter
goatsby
So my Q should be here early next week and I was digging through my drawers (no pun intended) to see if I had a 49mm filter to use, and found an old Leica UV/IR from my now M8. I remember hearing that these filters are best served at 35mm and narrower. Has anyone thrown an old UV/IR filter on the Q? Any thoughts if it's a good or bad idea? I am going to try it out and see unless someone has a negative experience from doing so..
x
 I put a UV filter on mine mostly to give a little extra protection to the lens, I'd be curious if that's a bad idea. Seems with a fixed lens at this price point, you want to make sure you take some extra precautions. That said, if I found that adding a UV filter might compromise the IQ, I'd take it right off.
I am using a Zeiss T* that was originally made for the Sony NEX 24/1.8. I just had one sitting around.
If I were to buy a new one, I'd go for B+W 010 - the simple model. No issues whatsoever and I spent hours comparing with/without filter a few years ago. As far as I am concerned, there is no visible impact other than flare and vignetting on anything wider than 21mm depending on the design of the lens.
Guest JonathanP
The key thing here is the IR block part of the OP's filter - usually this is implemented by several coatings that are spaced to cause destructive interference at IR frequencies (typically the spacing is 1/4 wavelength). The distance (light path) between the coatings is thus critical to the operation of the filter and is dependant on the angle at which the light hits the filter. For wide angle of views the edge performance is likely to deteriorate because of the angle of incidence, one of the reasons that this type of filter is not recommended for wider than 35mm.
The simpler UV only filters don't require such complex coatings and can be used on wide angle lenses. I'd echo the advise above and use a B+W MRC 010 or 007 filter for protection - I've found those filters the easiest to clean and apart from watching out for reflections at night pretty much unnoticeable in use.
Jonathan
