andybarton Posted May 28, 2007 Share #1 Posted May 28, 2007 Advertisement (gone after registration) Neither Vuescan nor Nikon's software can see my scanner. It was fine last time I used it. These things seem to have an incredibly short life-span. My Minolta one previously only lasted a couple of years, and it's not like I am a heavy user... I have tried a System Restart, and changing USB ports (which work fine with other peripherals) but to no avail. I have also changed USB leads and computers. Looks like a trip back to Nikon-land... Link to post Share on other sites More sharing options...
Advertisement Posted May 28, 2007 Posted May 28, 2007 Hi andybarton, Take a look here Nikon Coolscan V no longer seen by computer . I'm sure you'll find what you were looking for!
Guest Bernd Banken Posted May 28, 2007 Share #2 Posted May 28, 2007 Andy, did you try another USB cable? Bernd Link to post Share on other sites More sharing options...
andybarton Posted May 28, 2007 Author Share #3 Posted May 28, 2007 I have changed everything. Link to post Share on other sites More sharing options...
xrogers Posted May 28, 2007 Share #4 Posted May 28, 2007 Andy, if you can, try it on another computer. --clyde Link to post Share on other sites More sharing options...
andybarton Posted May 28, 2007 Author Share #5 Posted May 28, 2007 Done that... Link to post Share on other sites More sharing options...
Sandokan Posted May 28, 2007 Share #6 Posted May 28, 2007 Hi Andy, Is this with a PC? Try going into:- Right Click "My Computer" & choose "Properties" From "Hardware" Tab, choose "Device Manager" Under "USB Device Controllers" you should see the Nikon Scanner. If you do not see it, then check other USB devices appear (if not then your USB controller on the PC has a problem). If other devices appear, then the Nikon has a problem with its USB controller. If everything is OK here, but you do not see it through the software, then try uninstalling the Nikon scanner; go into the registry and make sure all references to Nikon are deleted; before re-installing the scanner software. If you are on a Mac - then my Unix skills (non-existant) do not help in determining if the USB controller is actually seeing the device and something else is the problem - sorry. Yours, Ravi Link to post Share on other sites More sharing options...
andybarton Posted May 28, 2007 Author Share #7 Posted May 28, 2007 Advertisement (gone after registration) PC? Me? LOL! No, it's an Intel Mac running 10.4.9 It's definitely a dead scanner. Thanks for the help, guys. Link to post Share on other sites More sharing options...
Sandokan Posted May 28, 2007 Share #8 Posted May 28, 2007 Oops - I couldnt remember from other discussions which religeon you were - and of course I always confuse you and Steve Unsworth as you are both north of the Watford Gap and south of Hadrians Wall Anyway, I know how to fix PC problems but not Unix or Mac ones - guess where the majority of sh** happens and where the money can be earned to fix them... I can fix SCSI problems on a Mac, but that was the only troubleshooting I ever had to do. I guess you should be able to go into the command prompt and show devices as it is running FreeBSD but have no idea which command to use... Good luck - but dont you have a DMR for all your new work, so I hope you wont be suffering without it? Link to post Share on other sites More sharing options...
andybarton Posted May 29, 2007 Author Share #9 Posted May 29, 2007 Unix stuff is beyond me too! I do have the DMR, of course, but I still enjoy using the M2 and R4 and therefore need my scanner. I'll send it to Nikon for some TLC. Link to post Share on other sites More sharing options...
pierovitch Posted May 29, 2007 Share #10 Posted May 29, 2007 Andy Try using the DMR and a good macrolens to dupe slides and negatives. It takes a little playing with the transfer curves in photoshop and a bit of USM tailored to the lens you use, but the results can capture a the full resolution of a Fujichrome or Kodachrome easily with lees grain than a scanner if you use a well diffused light source. I prefer it to the coolscan. Cheers Pierre Pierre's Overview - RedBubble. Link to post Share on other sites More sharing options...
larry Posted May 29, 2007 Share #11 Posted May 29, 2007 Andy, Sorry to hear that you're having this problem. (I have the same scanner, but it's been fine so far.) We had one with the same symptoms go down in our art department a few years ago. I don't remember the cause, but only that is was at Nikon USA repair for many, many months. I hope Nikon U.K. is more efficient. Larry Link to post Share on other sites More sharing options...
Photoskeptic Posted May 29, 2007 Share #12 Posted May 29, 2007 Andy, life sucks and then your scanner dies. Isn't that the way the saying goes? Sorry for your distress. One more thing you might try is to unplug all other USB devices from the computer. I have to do this with my Minolta when scanning. I had a similar problem and called Sonolta. The tech there correctly identified the problem. May be a long shot but worth a try. Link to post Share on other sites More sharing options...
