Softness of Noctilux 1.0?
adli
I have the last edition of the Noctilux 1.0. I am aware that this lens is known for being soft wide open, but my lens is much softer that I expected. Getting focus confirmation with focus peeking is impossible without stepping down several steps.
Attached crop of test shots at 1 meter wide open, is the lens supposed to be this soft?
Here is a sample with the lens stoppet down to 5.6.  Much sharper, but you can also see the famous focus shift.
I have also done the test at 1.5 and 2 meters. Same softness wide open at those distances.
Here's a cropped sample of mine taken wide open at 1m. It's a little soft up close but it should noticeably improve at mid distance. If you're not seeing improvements at further distances its probably a good idea to get the lens checked.
Adli, which body are you using?  Are you sure of the calibration of your RF camera body?
I have a Nocti 1.0 e58 and it is  performing fine.
I am using a M240. With my 75 cron ASPH it is biting sharp, so the body seems to be fine. Attached is a sample taken with the 75 cron, if I close in, I can count the specks on the surface on the Spyder.
My Nocti shows the same softness on the SL, so I suspect the problem is the lens, not the body.
I have a 75mm Summilux which was, when I first looked at it, way off focus wide open, and I do mean way off. I bought it on the basis that the price would include a visit to Leica and 6-bit coding. I now have the lens and it is spot on with regard to focus wide open and surprisingly well performing wide open. Whatever Leica have done they have done it very well. Stopped down I'm struggling to tell it apart from the 75mm Summicron! My point? A good service from Leica should bring it up to spec, and it does look well out wide open even from your web posted pix (but not as far out as the 75 Summilux was if that's any help).
After reading the initial post, decided to check my Noctilux 1.0 to see if similar as I often get too soft wide open on the M, but mostly due to being hand held it turns out.  I tested it on a tripod and was fine and sharp where it should be wide open.  In contrast, on the T I seem to do much better focusing with this lens.  Can't explain why.  Could be because harder to push shutter button on the M which is causing camera shake in my case.  Anyway, my point is if the original shots were not with a tripod, might want to double check before sending it in for repair.  Just a suggestion.
All tests done on tripod with cable release.
....  Anyway, my point is if the original shots were not with a tripod, might want to double check before sending it in for repair.  Just a suggestion.
I have a LensCal. I don't think the Noctilux is an easy lens to test on it. Even my 0.95 glows on the LensCal. High contrast black to white scenes is where it's famous "glow" is most pronounced. You're accentuating the biggest flaw/best thing about the f1 with that test.
Try a test on a lower contrast subject like a brick wall in shade at 45 degrees. I think you notice less glow there.
Gordon
the lens is soft wide open- on my camera it barely registers focus peaking wide open at f1. In fact you only get 'peaks' if you zoom into the image. At zero magnification no 'peaking'. However your sample images do look particularly soft. here are a few shots from mine wide open (with one crop)- and the last one stopped down to f8 (with crop):
Well, I don't get focus peak at 1:10 magnification, so I guess mine is a bit softer than yours. Solms next I expect.
Very interesting thread!
I also own a 1.0 E60 Nocti version 3, and it is indeed soft.
I intend to get a SL soon, and wanted to use the Nocti with it.
However, it might be very well possible that the 1.0 is too soft to allow a very effective focus peaking on the SL.
Might it be worth sending it to Wetzar for optimizing it?
Not sure if this will bring anything.....
In 3 days time, I  will have the SL to try it with the Nocti.
John
I tried mine with the SL, and was not able to get focus peking at 1.0. This was a disapointment, because the Nocti was one of the reasons I considered the SL. HopefullyLeica can optimise it, if not I consider selling it.
Its a good idea to have your nocti calibrated with the camera and you won't have too much problems nailing focus with it. I found a better sample to compare it to, you can see that it glows but there's still detail at the point of focus. Reflections of highlights will accentuate the glow so that might be the effect you're seeing with the lenscal.
we are in exactly the same boat Arne!
We might have to swap to a 0.95 or a 50lux!
John
