close up lenses
ECohen
Sometiimes it would be nice to focus closer.
Can anyone think of reason I cant/shouldn't  use  Heilopan or B&W close up lenses ( +1 +2 +3 ) with Leica's  50mm Summicron or the  35mm  Summicron lenses?
I'm my days of shooing with Hasselblads I used a set of Proxar's with no loss of sharpness.
I am aware I'll need to use the EVF or live view......on my 240M-P
Opinions and suggestion's welcome....Thanks
I haven't used those close up lens fittings but interested what others have to say.  I use a Leica R Apo Macro 100mm lens on my M240 with the R to M converter for close up work.  A lens I would never part with.
I use Nikon 3T and 4T closeup lenses with step-up adapters (they are natively 52mm, a side benefit of which is an e39 lens is not using the outer regions).  Those are achromat doublet lenses which I found far superior to any single-element closeup lenses I ever used.  If the B+W and Heliopans you speak of are doublets then I'm sure they are excellent.   Another possibility is an OUFRO extension tube mounted aft of the lens.  Depends on how close you want/need to get.  And depending also on how large you want to print.  It may work out perfectly well to simply shoot at 0.7m and crop.
The 10mm extension rings (OUFRO copy) from China have a cost in the 60-70 Euro range... I have a pair of,  and they are well made (heavier than the original OUFRO, which I have too... they have used a different alloy and the build is very robust) : you can keep 1 or 2 easily into bag or pocket and have a portable closeup set which works very fine with lenses in the 50-90mm range (personally, I use them mostly with Summicron 50 and Summarit 75).  I don't love closeup lenses... probably for I haven't ever tried a good quality one... but those rings today are imho the best solution for a quick closeup set : the time to mount is almost the same, and you haven't one more optical glass to take care of... ;)
