Draining battery
x
Based on your description, it seems you have a shorted battery,  I suggest locate another battery and test.  I assume the battery you are using is the Leica original?
There are several post as to 3rd party batteries that seem to work fine.  I am using Panasonic and Sigma branded batteries which are the same form factor.
If the issue continues with another battery then for sure you will need to return the Q for warranty.
Good luck to you.
