How long until new firmware?
leffe
I have had one hangup when the camera was going into sleep mose, it hung with the Leica logo and only removing the battery resolved the issue.  Luckily only once so far.  It does suggest that there are probably some bugs to be stomped out.
Leica is not very fast for the firmwares...
I think that it is necessary to envisage approximately one year after the release of the device for a first update.
Guy
I should imagine it will be more a question of months as there are one or two minor bugs that will need to be addressed. Whether or not a firmware is released that makes any operational changes who knows
Since the Q is not readily available for purchase, I'm holding out in hope they do a firmware upgrade to allow at least 5 exposure bracketing and exposures longer than 30 seconds. Others have pointed out there are workarounds, but that doesn't work for me. Those are both pretty common features on most cameras so I'm surprised they were not included to begin with.
These would be among the least likely changes brought by a hypothetical future firmware update.
You are probably right, but nothing wrong with hoping while I wait for supply to catch up with demand. I'm not the only one asking and hoping these features might be added.
My hope is they improve the options with the EVF/LCD. The delay with the eye sensor is very noticeable and what I really want is configuration and review on the LCD, everything else in the EVF.
Next up would be a bit more options on how auto ISO and shutter speed are handled (I doubt I'll get that).
There are a few others on my wish list, but I assume we'll only see the screen thing addressed.
In case you haven't noticed this, in the menu under "Display Settings," you can select "Auto - high sense" or "Auto - Low Sense"  If you select the Low Sense setting, there is a delay before the switch takes place.  If you select the "High Sense setting it switches very fast and it is merely a blink.  Check your settings.  I know at first, I switched my setting to Low to avoid having the LCD switch to EVF when my hand was close to the viewfinder then forgot about it.  Later I kept noticing the lag overtime I raised the camera to shoot.  Then I discovered that changing this setting to High resulted in fast switching so that is where I leave it.
I had wondered what the high-vs.-low sensitivity meant, but I've always had it set to "high sensitivity" and there's still this half second delay when it comes to my eye. It's minor, I know, but I become conscious of it every time I bring the camera to my eye.
-jbl
That happened to me last week. A quick battery removal fixed it as well. I am guessing firmware will come after the mystery camera is released.
He probably said that because it is a request that users have had since the X1 and Leica has ignored that request so far.  One possible explanation is that Leica uses the JPG for the review function and if it didn't store it on the SD card, it would have to store it in buffer memory or recreate it each time which would slow the camera down, so they write it to the SD card.  Just a guess... :)
