msbel Posted August 2, 2015 Share #1 Posted August 2, 2015 Advertisement (gone after registration) For some reason, after setting jpeg saturation settings to monochrome on my Q, it's not coming up on the Live View/EVF in b/w. Just color. After a capture, it is b/w on display. This was not the case until now. Not sure why. I have tried this with removing/reinserting the battery in case it's that ol' fix-a-bug gestalt. Did not work. Changed focus settings -as I read this may happen on tracking focus - never use it - just normal single point -- and again, only color. ISO at 3200. Any ideas? Link to post Share on other sites More sharing options...
Advertisement Posted August 2, 2015 Posted August 2, 2015 Hi msbel, Take a look here Leica Q monochrome jpeg setting not working now. I'm sure you'll find what you were looking for!
thighslapper Posted August 2, 2015 Share #2 Posted August 2, 2015 (edited) Are you sure you haven't inadvertently changed to one of the scene modes ....... instead of the default PASM ? They override all the JPG settings ..... Edited August 2, 2015 by thighslapper Link to post Share on other sites More sharing options...
viramati Posted August 2, 2015 Share #3 Posted August 2, 2015 (edited) As I reported the tracking issue to leica it would be helpful if you could see what settings are causing this to happen Edited August 2, 2015 by viramati Link to post Share on other sites More sharing options...
viramati Posted August 3, 2015 Share #4 Posted August 3, 2015 You could also try a full 'reset' which will take the camera back to it's default settings Link to post Share on other sites More sharing options...
msbel Posted August 3, 2015 Author Share #5 Posted August 3, 2015 Hey all thanks for the advice. What I found out is if I change the video setting to monochrome, the display will go b/w, however when setting video back to Standard, and changing still mode to mono, the display stays on color. PASM - yes, that is what it is set to - thought I did switch back and forth between each setting DURING exploring this bug. So for the meantime, either I have settings wrong, and video is overriding stills, or it's a bug. I will try a reset tonight, and let you know. Link to post Share on other sites More sharing options...
msbel Posted August 4, 2015 Author Share #6 Posted August 4, 2015 Reset took care of it. Seemed stuck in video mode was the challenge - and I did not even put it into that mode at all. Oh well, that ol's Leica bug mystique Link to post Share on other sites More sharing options...
Lou Walter Wilson Posted May 16, 2020 Share #7 Posted May 16, 2020 (edited) Advertisement (gone after registration) I had the same issue of not being able to change to monochrome. Instead of reseting the camera I realized I had to go into video setting and change to monochrome there. I don'r know why but changing from the Jpeg setting does not work. I did it three times to make sure I was not crazy. Also without going through the video setting just set monochrome in jpeg setting and just keep pressing the display button (centre of the circle) and the display will rotate between full colour, mono and even mono with levels! Edited May 16, 2020 by Lou Walter Wilson update Link to post Share on other sites More sharing options...
Leica Guy Posted May 18, 2020 Share #8 Posted May 18, 2020 I’m not following what you all are doing. On my camera I choose Film Style to BWnat. That does it. I only shoot RAW and not jpg’s. It has nothing to do with video on my camera. What am I missing? I see B&W in the displays. I use Focus Peaking in red and it shows up very nicely against the B&W images. Link to post Share on other sites More sharing options...
Siriusone59 Posted May 18, 2020 Share #9 Posted May 18, 2020 1 hour ago, Leica Guy said: I’m not following what you all are doing. On my camera I choose Film Style to BWnat. That does it. I only shoot RAW and not jpg’s. It has nothing to do with video on my camera. What am I missing? I see B&W in the displays. I use Focus Peaking in red and it shows up very nicely against the B&W images. I think the OP is using a Q and not the Q2 that has the film style selections. Link to post Share on other sites More sharing options...
haroldc Posted May 18, 2020 Share #10 Posted May 18, 2020 On my QP, to view the EVF and LCD in B&W, I set the following: --> JPEG Settings --> Saturation --> Monochrome Like Leica Guy, I have the camera to shoot only RAWs and never take JPEGs. I never touch the video settings. Link to post Share on other sites More sharing options...
Leica Guy Posted May 18, 2020 Share #11 Posted May 18, 2020 5 hours ago, Siriusone59 said: I think the OP is using a Q and not the Q2 that has the film style selections. Thanks for the correction. I had not realized it was not with a Q2. Link to post Share on other sites More sharing options...
