almoore Posted June 30, 2015 Share #1 Posted June 30, 2015 Advertisement (gone after registration) I'm guessing that the Q evf - like every other current evf - is hopeless in very bright sunlight, so, with that in mind, has anybody assessed how accurately a 28mm SLOOZ aligns with the final image? Link to post Share on other sites More sharing options...
Advertisement Posted June 30, 2015 Posted June 30, 2015 Hi almoore, Take a look here Does a 28mm brightline align with the Q? . I'm sure you'll find what you were looking for!
viramati Posted June 30, 2015 Share #2 Posted June 30, 2015 The EVF is perfect in bright sunshine and in very dim light. As it is an EVF (electronic viewfinder) of course you get to see the full frame of the final image . There are only bright-lines if you use the 35 or 50mm crop option. The LCD is indeed hard to see in sunshine Link to post Share on other sites More sharing options...
almoore Posted June 30, 2015 Author Share #3 Posted June 30, 2015 The EVF is perfect in bright sunshine... Really? That would represent a major breakthrough for an EVF. My experience with EVFs has been with Sony A7s. I now actually prefer EVFs in lower light to either rangefinders or SLRs, but until now I've found them too dim not to be frustrating in intense sunlight. Link to post Share on other sites More sharing options...
viramati Posted June 30, 2015 Share #4 Posted June 30, 2015 Really? That would represent a major breakthrough for an EVF. My experience with EVFs has been with Sony A7s. I now actually prefer EVFs in lower light to either rangefinders or SLRs, but until now I've found them too dim not to be frustrating in intense sunlight. Well of course it's not an OVF but it is very good and even my A7s and A7II are far from 'hopeless' though certainly not at their best in bright sunlight with high contrast subjects. By the way do you have your EVF set to high resolution with the A7s as it does make a difference? I certainly don't find it to be 'dim in any way Link to post Share on other sites More sharing options...
almoore Posted June 30, 2015 Author Share #5 Posted June 30, 2015 Well of course it's not an OVF but it is very good and even my A7s and A7II are far from 'hopeless' though certainly not at their best in bright sunlight with high contrast subjects. By the way do you have your EVF set to high resolution with the A7s as it does make a difference? I certainly don't find it to be 'dim in any way Just to be clear, I don't find A7s to be unusable in bright sunlight but I do find them to be distinctly sub-optimal. I've just glanced into the menu and I have the EVFs set to 'manual' rather than 'auto' and at '+2' which appears to be the brightest setting. Where exactly (if you remember) is the option to change resolution? It crosses my mind that we might have different definitions of bright sunlight. During the winter and early spring I was working in the north of Europe and found the Sony EVFs to be a revelation in comparison to the finders of the 5D3s I normally work with, whereas I'm currently in the tropics and between dawn and dusk I'm far more comfortable with OVFs. One of my A7s even has an old Leica SBLOO finder semi-permanently gaffer-taped to the hotshoe for daytime use with a 35 - it looks horribly inelegant but works surprisingly well. Do you find the Q EVF significantly better than the Sony? Link to post Share on other sites More sharing options...
digitalfx Posted June 30, 2015 Share #6 Posted June 30, 2015 I have no issues at all with the EVF in daylight. You will need to test drive a Q though, because it sounds like you have an issue with EVF's that I don't experience. My .02...if you think you need a OVF for the Q...you don't want this camera. Link to post Share on other sites More sharing options...
viramati Posted June 30, 2015 Share #7 Posted June 30, 2015 Advertisement (gone after registration) Just to be clear, I don't find A7s to be unusable in bright sunlight but I do find them to be distinctly sub-optimal. I've just glanced into the menu and I have the EVFs set to 'manual' rather than 'auto' and at '+2' which appears to be the brightest setting. Where exactly (if you remember) is the option to change resolution? It crosses my mind that we might have different definitions of bright sunlight. During the winter and early spring I was working in the north of Europe and found the Sony EVFs to be a revelation in comparison to the finders of the 5D3s I normally work with, whereas I'm currently in the tropics and between dawn and dusk I'm far more comfortable with OVFs. One of my A7s even has an old Leica SBLOO finder semi-permanently gaffer-taped to the hotshoe for daytime use with a 35 - it looks horribly inelegant but works surprisingly well. Do you find the Q EVF significantly better than the Sony? Significantly better maybe not but it does seem in a way smoother and certainly is bright enough. On my Sony A7's I have the EVF set to brightness +1 and in the suitcases 2nd menu I have EVF quality set to high Link to post Share on other sites More sharing options...
almoore Posted July 1, 2015 Author Share #8 Posted July 1, 2015 in the suitcases 2nd menu I have EVF quality set to high Thanks, just checked and I have 'Display Quality' set to "High'. I guess we all see things differently. I'm definitely not the only person to have issues with even recent EVFs in intense sunlight, so my question remains: has anybody tried a brightline finder on the Q? Link to post Share on other sites More sharing options...
viramati Posted July 1, 2015 Share #9 Posted July 1, 2015 I have finally understood your question you want to mount a bright line OVF in the hotshot. I suppose as always it will be approximate. But I will try it out with my frankenfinder for you later on Link to post Share on other sites More sharing options...
almoore Posted July 1, 2015 Author Share #10 Posted July 1, 2015 I have finally understood your question Eureka! Thank you for persevering in the face of my apparent stupidity. I probably shouldn't have referred to a SLOOZ but thought on such a geeky forum most people would know what it is. I live and learn... Link to post Share on other sites More sharing options...
viramati Posted July 1, 2015 Share #11 Posted July 1, 2015 Okay so I tried out the frankenfinder and set to 28mm it seemed to be pretty much as you would expect, not totally accurate but pretty good. Personally though I find the EVF fine in very bright light, I was out and about in London yesterday in bright sunshine and had no problem. Link to post Share on other sites More sharing options...
almoore Posted July 1, 2015 Author Share #12 Posted July 1, 2015 Okay so I tried out the frankenfinder and set to 28mm it seemed to be...pretty good Cheers. Link to post Share on other sites More sharing options...
screwmount Posted July 2, 2015 Share #13 Posted July 2, 2015 I don't understand the discussion. Why should it not be possible to mount an external viewfinder on a camera that offers a hotshoe? Link to post Share on other sites More sharing options...
almoore Posted July 2, 2015 Author Share #14 Posted July 2, 2015 I don't understand the discussion. Why should it not be possible to mount an external viewfinder on a camera that offers a hotshoe? I don't understand your misunderstanding. Nobody has suggested that it wouldn't be possible. I've asked if anybody has ascertained whether a particular external finder - the old 28mm SLOOZ - aligns well on the Q. Just because the angle of view will broadly correlate with the lens it doesn't automatically follow that it won't be offset in one direction or another. Link to post Share on other sites More sharing options...
screwmount Posted July 2, 2015 Share #15 Posted July 2, 2015 like on any other camera as well Link to post Share on other sites More sharing options...
Peter H Posted July 2, 2015 Share #16 Posted July 2, 2015 like on any other camera as well Which is presumably why he's asking the question specifically in relation to the Q. It seems a perfectly straightforward question. Link to post Share on other sites More sharing options...
wattsy Posted July 2, 2015 Share #17 Posted July 2, 2015 Bizarre what people will pick a fight about. Link to post Share on other sites More sharing options...
earleygallery Posted July 2, 2015 Share #18 Posted July 2, 2015 Bizarre what people will pick a fight about. Oi, what's your problem!! Link to post Share on other sites More sharing options...
Peter H Posted July 2, 2015 Share #19 Posted July 2, 2015 Oi, what's your problem!! I do not disagree with what you have to say, but I'll defend to the death my right to pick a stupid argument with you over it. Link to post Share on other sites More sharing options...
bernie.lcf Posted July 2, 2015 Share #20 Posted July 2, 2015 The issue with add on optical viewfinders is that none of them is 100% accurate (obviously) and accuracy depends on distance to subject. There is a couple of solutions to this: There are some viewfinders that can be adjusted for focus distance. The ancient Leica Vidom is such an example and so is the current Frankenfinder. Some viewfinders will have additional (e.g. dotted) lines to show the framing for (usually) close distances: e.g. the X1 finder A lot of viewfinders totally ignore this and the user is left alone. Why am I bringin this up? If all the viewfinders are somewhat inaccurate, then in my opinion the it doesn't matter whether the framelines are 95% or 96% accurate. First of all you can look at the result on the display, adjust and shoot again. Second, it probably makes more sense to consider the other factors in choosing your viewfinder: how big, how clear, how bright... Link to post Share on other sites More sharing options...
