esophoria Posted June 20, 2015 Share #1 Posted June 20, 2015 Advertisement (gone after registration) I had assumed that LR 6 would not be able to read Leica Q DNG files at this time. I imported some photos and the DNG files were read and processed. It also noted that there was a jpg side car file along for the ride. Can I begin to truly process the Q DNG files in LR or do I need to wait for an update to LR? Link to post Share on other sites More sharing options...
Advertisement Posted June 20, 2015 Posted June 20, 2015 Hi esophoria, Take a look here Leica Q DNG Files . I'm sure you'll find what you were looking for!
jaapv Posted June 20, 2015 Share #2 Posted June 20, 2015 If LR can read, LR can process. Link to post Share on other sites More sharing options...
bernie.lcf Posted June 20, 2015 Share #3 Posted June 20, 2015 I got my Q on Monday and have been using Photoshop and Lightroom ever since - before and after the CC2015 update that must have happened around Wednesday or so Link to post Share on other sites More sharing options...
alee Posted June 20, 2015 Share #4 Posted June 20, 2015 DNG is an Adobe format. It doesn't get more LR/PS friendly than that. Link to post Share on other sites More sharing options...
Guest Posted June 21, 2015 Share #5 Posted June 21, 2015 I'm no expert but I've read that LR does need a colour profile update or some such to fully support the Q. Link to post Share on other sites More sharing options...
bernie.lcf Posted June 21, 2015 Share #6 Posted June 21, 2015 I'm no expert but I've read that LR does need a colour profile update or some such to fully support the Q. Lightroom can use the embedded profile or the Adobe profile. As there is no Adobe profile available for the Q, it uses the embedded profile. If you go to the Develop pane, Camera Calibration you will find that Lightroom usually defaults to "Adobe (Standard)" but allows you to pick "Embedded". For the Q, "Adobe (Standard)" is not currently available and therefore it chooses "Embedded" This impacts color reproduction. While the embedded profile is not bad, the colors will slightly change as soon as Adobe has a profile available (simply because it will default to its profile rather than the one supplied by the camera) Other than that, there is no limitation whatsoever EDIT: If you are wondering what the color changes might be, here are a few examples: For the T it pretty much comes down to the Leica profile (embedded) being a tiny bit more saturated. Skin looks better (at least my wife's skin does); there is a hint more red. For the X-Vario it's the same For the M8 it just seems much lighter - the M8 embedded profile seems darker Link to post Share on other sites More sharing options...
digitalfx Posted June 21, 2015 Share #7 Posted June 21, 2015 Advertisement (gone after registration) I'm no expert but I've read that LR does need a colour profile update or some such to fully support the Q. The changes are typically very subtle color changes. Link to post Share on other sites More sharing options...
azuled Posted June 21, 2015 Share #8 Posted June 21, 2015 Related to this, when importing DNG files from the Q using "Copy as DNG" do you receive an error that "non raw files were not converted?" Previous versions of LR would convert the Leica DNG files to the most recent Adobe version of the file and apply the Adobe lossless compression to them, but that seems to not be the case now. Anyone else have similar experiences? Link to post Share on other sites More sharing options...
digitalfx Posted June 21, 2015 Share #9 Posted June 21, 2015 you sure this wasn't referring to the JPEG files? Link to post Share on other sites More sharing options...
azuled Posted June 21, 2015 Share #10 Posted June 21, 2015 you sure this wasn't referring to the JPEG files? Yes, I have JPEG files turned off entirely. Also, I have noticed that the files don't change size after import, but they do if I manually select "Convert to DNG" later. Link to post Share on other sites More sharing options...
digitalfx Posted June 21, 2015 Share #11 Posted June 21, 2015 What is the purpose of "copy as DNG"? I generally just import and don't receive any errors.. EDIT: ok I see the option now...but why are you choosing this? The camera records DNG files, why would you then convert to DNG as opposed to just "copy" which is what I do. Link to post Share on other sites More sharing options...
azuled Posted June 21, 2015 Share #12 Posted June 21, 2015 What is the purpose of "copy as DNG"? I generally just import and don't receive any errors "Copy as DNG" is mostly used for "non-dng raw" files, and converts them to DNG as it copies them into the library. In previous versions it would apply the Adobe DNG compression feature to imported files (a nice space saving feature without loss of image data). It appears that Adobe now intends that we use "Copy" or "Move" rather than "Copy as DNG" to import existing DNG files, but I wish that they had mentioned this change so that I wasn't caught unaware. Link to post Share on other sites More sharing options...
algrove Posted June 24, 2015 Share #13 Posted June 24, 2015 Life is often more complicated than it has to be. Link to post Share on other sites More sharing options...
