MM, M240, MM246 comparison images
thighslapper
and another ......
  • Replies 186
  • Created
  • Last Reply
First is 320 iso ....... second is 8000 iso
and here's a shot of her vile moggie .... who used to spend most of it's time trying to scratch me but has turned over a new leaf and become a bit more sociable .....
again ....... 8000 iso
His test part two is obviously failed. The amount of moire and the apparent pixel size in MM2 images tells that something has gone badly wrong in prosessing.
The moire you see is from the M(240) in the comparison with the M246. Any color camera will show moire at this level of fine detail.
thighslapper
Love the shots. Like Farkas showed ISO 8000 is very easily doable with the M246. What type of PP did you do on the 8000 shots? TIA
Just some sharpening and NR ..... highlights down a bit on the top shot as it was under an awning and the background was blown ...... and 1 and 3 (in particular) have been cropped a fair bit.
Unlike the MM1 the basic DNG's in LR seem to need very little adjustment and most look fine as is.
Puts .......  :huh:
this is precisely why I used real world images taken by mr. average and processed them to get the best results possible.
no normal photographer just takes photos of test charts, uses unsharpened images with no NR (when it helps ...... although Puts is rather vague about precisely what he has done)  and then views them at 200%.
He's being Scientific
. . . . and this would be a grand thing IF we all took images of test charts and developed them in Iridient (which is great, but rather subject to Moire).
Fortunately we don't all take pictures of test charts.
You're doing a grand job here (and it's great to see your daughter!)
No, I was referring to test part two. There is something wrong.  Parts 1 and 3 show logical results.
Actually I was surprised how well the M240 did….
I've made some gorgeous b/w prints, using both the M8.2 and M240, typically at lower ISOs.  None of these cameras provide an excuse for inferior results if the image and the rest of the workflow suits.  So, I'm not really surprised, but will be interested to see if the MM246 takes things up a notch without going to super high ISO.
Jeff
I've had great results from the MM at up to ISO 5000, 3200 if I print large.  I actually got to try the M246 yesterday and was very impressed, but was still quite impressed with my MM images the same evening.
These cameras are both far better than I am at using them.
M246 with 12mm Voigtlander.  f8. 320iso. Shading correction off.
Exposed towards the sky but managed to pull the shadow detail quite well.
3 more MM246 with Voigtlander 12mm.
Kudos to Thighslapper for the comparisons.  I think they are fascinating, including all the many reactions.  Because there is no empirical way to measure "better" or "worse" in these situations, it boils down to which look you like, and in my case, I like what I saw from the M246 so I will not cancel my order.  I have to admit though, that the differences are small except in extremely high ISOs, and maybe I am seeing what I want to see exactly because I have ordered one and don't want to admit that maybe I didn't need it.  Then I remind myself that this isn't at all about "need".  It is about "want".
The main differences become immediately apparent in usage ........ the old MM just feels antiquated and cumbersome in comparison ...... no idea if images are in focus as the screen is crappy, dodgy with long lenses or very fast lenses wide open, generally slower and fiddlier to use ......
Even if the performance was identical it would be worth changing ...........
....... and you will find the OOC images need very little PP ...... unlike my old MM images that needed a rinse with SEP2 to get the look that pleased me.
The MM1 was excellent ...... the MM2 is a whole lot better on a wide range of fronts and I am sure you won't be disappointed ....
