FredR Posted May 3, 2015 Share #1 Posted May 3, 2015 Advertisement (gone after registration) My M6TTL is 15 years old. With changes in battery manufacturing, what is the current* correct battery replacement? Thanks. Fred *Pun not intended. Link to post Share on other sites More sharing options...
Advertisement Posted May 3, 2015 Posted May 3, 2015 Hi FredR, Take a look here M6TTL battery spec . I'm sure you'll find what you were looking for!
FM2N Posted May 3, 2015 Share #2 Posted May 3, 2015 Fred, I also own a M6TTL, and normally I buy the Duracell Lithium 1/3N. But there are a lot more types from other companies you can also use. Marcus Link to post Share on other sites More sharing options...
jdlaing Posted May 3, 2015 Share #3 Posted May 3, 2015 Wein Cell MRB625 I believe will work as well. Link to post Share on other sites More sharing options...
FredR Posted May 3, 2015 Author Share #4 Posted May 3, 2015 Are these recommend batteries of the same voltage and capacity as the original specification such that no adjustment of exposure is required? Fred Link to post Share on other sites More sharing options...
FM2N Posted May 3, 2015 Share #5 Posted May 3, 2015 In the Leica manual is a list of all recommended types. I think that nearly all of them are still available and can be used without meter calibration. Link to post Share on other sites More sharing options...
FM2N Posted May 3, 2015 Share #6 Posted May 3, 2015 You can find the manual online, for example at http://www.butkus.org/chinon/leica/leica_m6/leica_m6.htm Link to post Share on other sites More sharing options...
FredR Posted May 3, 2015 Author Share #7 Posted May 3, 2015 Advertisement (gone after registration) Thank you! Link to post Share on other sites More sharing options...
gyoung Posted May 7, 2015 Share #8 Posted May 7, 2015 And for 'FM2N' the actual FM2N takes the same batteries as the M6ttl ☺ Gerry Link to post Share on other sites More sharing options...
