Filter for 39mm lenses - What are the numbers for?
It should be a polarising filter, and rotates in the mount, you look through it and turn it until you get the effect you want, then note the number which is at the top, then mount the filter on the lens and then rotate the front until the number you want is at he top, and then the film should see the same effect you saw looking through it.
An early and rather cumbersome way of using a polarising filter on a rangefinder camera, I have had one for about 40 years, and used a couple of times at least :rolleyes:
Later superceded by the ones with a built in hood which swing out through 180 degrees in frnt of the viewfinder.
Gerry
Gerry
So far so good then. This is what I was hoping for.
Thank you for the quick reply Gerry.
Looks like the long years weighed in on the filter, now it's stuck and doesn't rotate. Atleast I know what I should be doing and will attempt to get it to rotate again.
I'm currently using the universal polarizer you mention but it's quite cumbersome and I was hoping this little fella would be easier to use. Looks like the UniPol, though bulky, is still easier to use
  • 4 weeks later...
  • 2 weeks later...
Take two of these numbered polarizing filter.
The first polarization filter in front of your eye is for setting the number of the desired effect.
This number is transmitted to the second polarization filter, which remains threaded in front of the lens.
See my reply of 25 March above, can't see why you need 2 of them unless you are taking a whole long series with it.
Gerry
Of course a single numbered polarizing filter is sufficient if one is willing to take the filter on and off the lens every time one wants to adjust the lens to the desired efficiency.
But with two numbered polarizing filters it is easier and faster.
As this idea is not mine, please have a look at the pictures and the video.
http://www.ephotozine.com/article/kenko-rangefinder-polariser-2546
