Rewind Issue New MP/ Purpose of Film Speed Contacts
Just received my new MP film and it is a beautiful camera. Two questions:
Also shot my first three test rolls and all went fine except an issue with the rewind mechanism. When loading the second roll I probably did something wrong. I ran the camera empty a few times after that and couldn't replicate it. Dealer said to hold off on sending my warranty card in and he can exchange it if it happens again. I am 99% sure it was my error. Anyone else ever had an issue like this...rewind crank would not advance when I loaded the film and R lever was stayed in rewind position.
Also, you need to set the ISO on the MP. What is the purpose of film speed contacts? MP doesn't read film speed, I don't understand.
The rewind lever function can be tested without film with an open camera.
With the lever set to rewind the film, the film and bottom plate removed, the rewind lever should snap back into it's 12'o'clock position the moment you wind the advance lever.
I wind the advance lever one full time and release the shutter after removing the exposed film on principle.
This does:
- reset the rewind lever
- prepare the film advance so I can easily load the next roll and secure it with just a bit of tension to the sprockets (usually half an advance is enough for that)
I'm assuming you are talking about the film advance lever not advancing. And as you don't mention it and it would help in a diagnosis I'll ask the obvious missing question, had you tried firing the shutter? If the shutter was locked up and wouldn't fire you may have a problem, but if you had cocked the shutter and then removed the film the shutter will still need to be fired before you can load another film.
Steve
Steve
Steve, yes I misspoke, it was the film advance lever not advancing, Once I tried reloading the film it was fine. I tried shutter at all settings and it worked fine. Test rolls came back perfectly too. Dealer said this am once in awhile the R lever and film advance does "stick" when new. He advised to try a dry run withour film 6 times and see if it happens again. He has another unit and is happy to exchange. Thank you.
Not sure why you think that. The ISO needs to be set so that the exposure meter can give the correct measurement. All is explained in you camera's instuction manual...
Enjoy your MP - I certainly enjoy using mine! :)
Are you talking about the three brass coloured contacts in the middle of the back?
They are to tell the meter what film speed you have selected nothing to do with dx coding.
