Uncompressed DNG on the Monochrom
bobbywise
Hi,
My Monochrom arrived from Italy today.
Am I right in thinking that uncompressed DNG is only available from within the SET menu if you do the following "button dance":
Delete once
up twice
down four times
left three times
right three times
info once
With Well Wishes,
Rob
The M Monochrom does not offer compressed DNG, it shoots Uncompressed DNG when DNG is selected.
I would avoid using the Button dance on the M9 and M Monochrom. It produces uncompressed DNG files without bad-pixels mapped out with a different file extension. At High-ISO, it stores the black level file and takes longer to write to the SD card. If you get these files, simply rename them the ".dng" to process them in LR or whatever you use.
Button dance on the M8- the only way to get uncompressed files, but reverts after every power cycle.
So if I choose the DNG and JPG (fine) option, the DNG is uncompressed ?
Yep. Leica‘s lossy compression scheme isn’t suitable for monochrome raw data so this isn‘t offered as an option.
