shootinglulu Posted December 10, 2014 Share #1 Posted December 10, 2014 Advertisement (gone after registration) Hi there guys! I just bought a used M9 which has the worse case of horrid white balance correction I ever saw from a Leica. I think I'm correcting it ok in LR but my question is, is the sensor in this camera inferior to the others I've owned or is it just a worse White Balance issue? Any wisdom gratefully received.Thankyou! Link to post Share on other sites More sharing options...
Advertisement Posted December 10, 2014 Posted December 10, 2014 Hi shootinglulu, Take a look here M9 White balance . I'm sure you'll find what you were looking for!
Hamad Posted December 10, 2014 Share #2 Posted December 10, 2014 Shootinglulu ... indoor with Leica is a bit of yellow sided contras but outdoor it works perfect. I use to set the white balance manually on Calvin. after few shoots you will have a good idea what number to set where and then its all like a walk in the park. Link to post Share on other sites More sharing options...
mjh Posted December 10, 2014 Share #3 Posted December 10, 2014 The worst AWB was the original AWB of the M8 (that could hardly be called AWB at all). The AWB in the M9 works reasonably well. It wasn’t made for incandescent lighting, but then again, no AWB is. Link to post Share on other sites More sharing options...
jdlaing Posted December 10, 2014 Share #4 Posted December 10, 2014 The worst AWB was the original AWB of the M8 (that could hardly be called AWB at all). The AWB in the M9 works reasonably well. It wasn’t made for incandescent lighting, but then again, no AWB is. Do you mean, per chance, flourescent and not incandescent? Link to post Share on other sites More sharing options...
Jeff S Posted December 10, 2014 Share #5 Posted December 10, 2014 I just bought a used M9…… …...is the sensor in this camera inferior to the others I've owned Maybe not the sensor, but the cover glass is another story. Brave soul to pick up an M9 these days. More to your point, what settings are you using to start? Have you tried a white bal card, ColorChecker Passport, or the like? Jeff Link to post Share on other sites More sharing options...
shootinglulu Posted December 10, 2014 Author Share #6 Posted December 10, 2014 I've used a few M9's and WB was fine outside and with natural lighting but this copy is rendering everything an intense blue. WB is set to Daylight in the camera. I may return it. Thanks a lot for your help. Link to post Share on other sites More sharing options...
shootinglulu Posted December 10, 2014 Author Share #7 Posted December 10, 2014 Advertisement (gone after registration) Maybe not the sensor, but the cover glass is another story. Brave soul to pick up an M9 these days. More to your point, what settings are you using to start? Have you tried a white bal card, ColorChecker Passport, or the like? Jeff Maybe I should try a whitebal card but really I'm just wondering if the issue indicates a faulty sensor as no other M9 had this blue WB problem. Thankyou. Link to post Share on other sites More sharing options...
mjh Posted December 10, 2014 Share #8 Posted December 10, 2014 Do you mean, per chance, flourescent and not incandescent? Fluorescent lighting opens its own can of worms … The thing with incandescent lighting is just that it is usually and deliberately excluded from the range of colour temperatures that are fully corrected by the AWB – that range usually starts at 4000 K or thereabouts. Both tungsten and halogen lighting have colour temperatures well below that limit. (Years ago when I was in the business of testing cameras of all makes I originally started checking AWB performance with daylight and incandescent lighting, but soon gave up on the latter as no AWB was up to the task and was, as camera vendors assured me, never designed for this to begin with.) Link to post Share on other sites More sharing options...
jdlaing Posted December 10, 2014 Share #9 Posted December 10, 2014 Fluorescent lighting opens its own can of worms … The thing with incandescent lighting is just that it is usually and deliberately excluded from the range of colour temperatures that are fully corrected by the AWB – that range usually starts at 4000 K or thereabouts. Both tungsten and halogen lighting have colour temperatures well below that limit. (Years ago when I was in the business of testing cameras of all makes I originally started checking AWB performance with daylight and incandescent lighting, but soon gave up on the latter as no AWB was up to the task and was, as camera vendors assured me, never designed for this to begin with.) I have more trouble with fluorescent than I ever did with good old light bulbs. Link to post Share on other sites More sharing options...
wda Posted December 10, 2014 Share #10 Posted December 10, 2014 shootinglulu, I regard AWB merely as a starting point. I always capture Raw files. Often in average outdoors conditions colour rendering is surprisingly good. Indoors is a different matter. If I have any doubts about colour rendering, I always shoot a Pantone ColorChecker or Grey Card to aid correction in Lightroom. Very occasionally I will tweak the result to meet my recollection or preference for final colour rendering. Link to post Share on other sites More sharing options...
Jeff S Posted December 10, 2014 Share #11 Posted December 10, 2014 Maybe I should try a whitebal card but really I'm just wondering if the issue indicates a faulty sensor as no other M9 had this blue WB problem.Thankyou. Seeing is believing (and I trust you're actually shooting in daylight)….seems like a call to Service is in order. Jeff Link to post Share on other sites More sharing options...
sblutter Posted December 11, 2014 Share #12 Posted December 11, 2014 I'd try resetting all to default Mine is fine as is in daylight only, but I shoot in raw and adjust everything in post anyway - so don't care As see those settings as ballpark for the rear screen - have nothing to do with an eventual print Link to post Share on other sites More sharing options...
fore Posted January 1, 2015 Share #13 Posted January 1, 2015 I'd try resetting all to default Mine is fine as is in daylight only, but I shoot in raw and adjust everything in post anyway - so don't care As see those settings as ballpark for the rear screen - have nothing to do with an eventual print This is what I've been thinking...adj. white balance can be done in LR so does it really matter if using raw files? Link to post Share on other sites More sharing options...
wda Posted January 1, 2015 Share #14 Posted January 1, 2015 This is what I've been thinking...adj. white balance can be done in LR so does it really matter if using raw files? I believe it does matter. When you capture jpeg files, the camera has made a decision for you. Data is thrown away during file compression. So changes subsequently in LR can only be made to data left after compression in the camera. It is a 'no-win' situation. Sometimes beneficial changes can be made in LR; but only when working with Raw files do you have the best chance of getting an accurate or acceptable results. That is my understanding. Link to post Share on other sites More sharing options...
yossarian123 Posted January 1, 2015 Share #15 Posted January 1, 2015 Indoor WB on the M9 is generally terrible. I purchased a really cheap white balance lens cap and just snap a quick reference WB shot when I need to. Link to post Share on other sites More sharing options...
fore Posted January 1, 2015 Share #16 Posted January 1, 2015 I believe it does matter. When you capture jpeg files, the camera has made a decision for you. Data is thrown away during file compression. So changes subsequently in LR can only be made to data left after compression in the camera. It is a 'no-win' situation. Sometimes beneficial changes can be made in LR; but only when working with Raw files do you have the best chance of getting an accurate or acceptable results. That is my understanding. I see, so shooting jpegs WB matters, while shooting raw WB can be adj. in LR? This makes sense. Link to post Share on other sites More sharing options...
becker Posted January 1, 2015 Share #17 Posted January 1, 2015 Hi there guys! I just bought a used M9 which has the worse case of horrid white balance correction I ever saw from a Leica.! Yes it is, ( under indoor and mixed light cond.) nothing more to say Link to post Share on other sites More sharing options...
jaapv Posted January 1, 2015 Share #18 Posted January 1, 2015 Being lazy by nature, I prefer to have a decent starting point in a raw workflow as well. Life is too short to be spent twiddling eyedroppers and sliders. Shoot a grey card from time to time, it saves a whole lot of computer time. In general I find AWB on the M9 pretty good. However modern LED lighting and fluorescent are awful and tungsten too yellow, as these are on most digital cameras. The grey card feature on the M240 takes care of this and is a reason to upgrade by itself if one shoots in the evening often. Link to post Share on other sites More sharing options...
fore Posted January 1, 2015 Share #19 Posted January 1, 2015 That's a Very good point jaapv! Have any of you used one of those WB discs you shoot thru? Kind of a strange product and one I'm not sure that necessary. A sm grey card is lighter Link to post Share on other sites More sharing options...
wda Posted January 1, 2015 Share #20 Posted January 1, 2015 I see, so shooting jpegs WB matters, while shooting raw WB can be adj. in LR? This makes sense. Although that does not rule trying to get an appropriate WB during initial exposure. I invariably use a calibrated grey card at that time, then use the grey patch for telling LR how it was. That gives a purer starting point in PP which you can fine-tune to suit your personal preferences. Link to post Share on other sites More sharing options...
