How do you store your Lenses + Cameras?
johnpierce
I guess it depends on cost... I use the aluminum descant's that can be recharged in the oven from archival stores. But i keep them in half unzipped Leica leather cases, for air flow, and use them often.
Note that sunlight (UV) actually helps kill / prevent fungus. When I use lenses outside in humid weather or on a backpacking trip, I set on a window sill for a few days to be sure thoroughly dried and UV'd...
Probably the key is however you store the lens, be sure it is crisp and dry before putting it away...
My older stuff I keep in a glass display case. The central A/C is on pretty much all year round here so humidity isn't really a problem. Newer stuff I keep in plastic storage boxes in a closet with slatted doors, and again the A/C being on keeps the humidity at bay, but I also keep a product called Damp-Rid in the box. Those are crystals or flakes that sit in a perforated basket in the top of a plastic tub, absorb moisture and deposit it below in the tub. It needs the water dumped periodically and new flakes added to the basket. I used to use the rechargeable silica cannisters but recharging them in the oven was a PITA and I often forgot to do it. I have never had a fungus issue in two decades of living here.
  • 2 weeks later...
