1940 Leica IIIb...or not?
Cuthbert
Dear Leicisti, let me introduce myself: I'm Alex, I'm the happy owner of a 1960 M3, a 1980 M4-P, a 1972 M5 and now...a IIIb. I think.
I must confess I'm not a great expert about screw mounted Leicas, but I had a spare 1940 Summitar and I fancied about getting an appropriate camera for this lens. Last Saturday I dropped in a famous Leica shop in London and found what was sold as a IIIc serial number 345xxx, of course I immediately recognised that it was a IIIb and not a c and that it appeared to have a flash synch added after the war, however the price was reasonable and the camera looked like in good condition so I bought it.
At home I made some research and there are things on the top plate engraving that don't match up, in particular the camera is branded "Germany" (I don't think the Germans could export much in those days) and the serial number just has a dot instead of a line...the number itslef is shifted right, tough.
Here there are some pics of the camera:
At the moment the Summitar is at home so I use a Soviet Industar 61 in excellent shape:
So I would like to ask the opinion of some expert, is the camera 100% legit? I still have the receipt and the seller told me that should I change my mind I can come back and take another one, he also has a 335XXX available but this one was nicer.
BTW, legit or not the camera is an excellent performer, I took a test film, 38 exposures all came out pretty well with Sunny 16 rule.
Perhaps there's a little light leak in this pic taken backlight in front the sun:
I cannot see any flash sync, but if there is one than is not factory added. Upgrades to IIIb/f had top cover (not top plate) replaced with different shaping around the speed dial.
SN look quite fine for me, dot under o is not a dot but underline.
Jerzy
I definitely don't like the top engravings... it's true that wartime items are often made with some odd details (there were hard problems on the workforce' side) but,as you have pointed, the "Germany" writing and, above all, the s/n don't look good : this doesn't mean it is a Russian fake (frankly doesn't look at all such a thing), but maybe a 3rd party reconstruction... take note that, apart position, also the style of some digits ("3" , "4", maybe "5" too) aren't right...
thank you for the input guys, I agree that the conversion looks nicely done, I'm no expert about factor jobs but the rest of the camera doesn't look updated.
The top cover is debrassed and with a nice number of scratches as well, so it looks old to me.Is the shape correct for a IIIb? Could it be possible that the camera has Benn re-engraved/retopped when it received the flash synch? The rest of the camera looks legit to me.
I'd say it's a genuine IIIb. The R/F focus control ("diopter" adjustment) has a little knob at its end. So did the early IIIc, but starting with that model the frame counter arrow is at the rear, near the shutter release. The flash socket is neatly done, but it would probably have been lower if it had been done in the factory.
Yes, that 's the most probable hipotesis...a well done job, with some minor "errors" in the engravings, made on an original camera : all in all, not a bad item to have.
here is the factory added sync. Note different shape of flash socket. All screw mount Leicas did have it. Note as well tope cover with engraved numbers for flash adjustement around the dial speed. In order to accomodate flash sync contacts top cover have different shape than the original one and was always replaced as part of upgrade. Btw. I have an postwar upgrade from I to IIIa (not sync), Leica used as well top cover shaped as for sync Leicas however w/o engraved flash numbers.
jerzy
jerzy
Excuse m jay but doesn't the F have the sync installed more or less in the same positions as in my camera?
http://www.kenrockwell.com/leica/images/iiif/D3S_9660-1200.jpg
That's interesting, do I have to assume that besides the serial number and the writing "Germany" perhaps too bold the other engravings (Leica, DRP etc...) are correct?
They look 100% correct... their "strict originality" depends on how the lab did perform its "upgrade" job... which top they have used ... a spare part ? a top taken from a broken camera and re-numbered ?... who knows... :o
Hi, Look at http://www.l-camera-forum.com/leica-forum/leica-sammler-historica/172222-leica-umbauten.html in German Forum. There are pics of some upgrades there. Not all flashes shown there are done by Leica. Position of flash socket on IIIa/b synced is below the accessory shoe. This is different than on IIIf. But what I mentioned is that the socket itself has a different shape, and every factory flash upgrade had either top cover replaced for IIIa and some IIIc or a plate was added on IIIc around the speed dial. Purpose was to set up flash bulb ignition time which was different for various type/vendor of flash bulbs.
Btw. Has anyone of forum members have seen factory upgrade of IIIb to IIIb/f? did not come across yet.
Jerzy
Jerzy
It looks like they replaced one screw of the top cover with the flash synch...at least on the IIIa on the first page, and in that case they didn't have much choice since the viewfinder is far away from the rangefinder.
