corner fringing with CV15 and IR filter
jedisdl
x
Do you have firmware 1.102 and IRfilter+ lens recognition switched on?
Won't help him unless he's hand-coded his CV15, which most people have not yet been able to do cos of the cutaway on the mount adaptor...
That's true Tim, I'm so happy with the results of John's adapter, completely clean with a Leica filter, that I tend to forget that we are not all so lucky...:o
It's not color fringing, it's cyan drift from the filter. John's adapter (coding the lens as a WATE and setting it to 16 mm) should help a lot.
Cheers,
Sean,
Like many others, I emailed John and added my name to the long list of "adapter wanna- bees". Any knowledge of his production schedule. I suppose I could email him but don't want to bother an already busy guy! Thanks.
CD
Sean,
CD
Hi Carlos,
I have no idea, I'm afraid, but I bet it won't be too long.
Cheers,
Sean
Thanks to John's custom 9cm codeable adapter I no longer have any problems with vignetting or cyan drift using the CV 15 (coded as 16mm WATE) with a B+W 486 filter (mounted now with an O ring). Here is a shot taken today with this setup in one of the local gorges. Terrible contrasty lighting that I corrected a little with a contrast mask, but no need for any cyan drift or vignetting correction in post thanks to the 1.102 in camera correction.
