ernst_leitz Posted September 23, 2014 Share #1 Posted September 23, 2014 Advertisement (gone after registration) Having just discovered this wonderful plug-in I decided to test with some wide-angle lenses. I formerly used CornerFix but found it a bit cumbersome. First to test was CV 4,5/15 mm, worked just fine. Beautifully corrected images only a few clicks away. Now my problem: When I tried the same with Super-Angulon 3,4/21 I got this error message. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! I had the lens detection set off (M9). The calibration shots for the different lenses look similar in density and colour. I just can't understand why it won't work with the SA. Is there anyone who had the same problem and can give a few hints on how to fix it? Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! I had the lens detection set off (M9). The calibration shots for the different lenses look similar in density and colour. I just can't understand why it won't work with the SA. Is there anyone who had the same problem and can give a few hints on how to fix it? ' data-webShareUrl='https://www.l-camera-forum.com/topic/234418-dng-flat-field-lr-5-correction-problem/?do=findComment&comment=2676492'>More sharing options...
Advertisement Posted September 23, 2014 Posted September 23, 2014 Hi ernst_leitz, Take a look here DNG Flat Field LR 5 correction problem. I'm sure you'll find what you were looking for!
stickan1 Posted September 26, 2014 Share #2 Posted September 26, 2014 It happens now and then for me also and it is independent on the lens used, but more frequent with the wide ones. The problem seems to be the quality of the calibration image, it must really be flat field. I made a diffusor of some plastic but sometimes the process fails. 1 Quote Link to post Share on other sites More sharing options...
