Cleaning M8 sensor - How Often?
I've read many of the posts on cleaning the M8 sensor but my question is more about how often. I know this depends on where you are when you change lenses, climate conditions, etc.. However, if you change to another lense, do you also clean the sensor or can you do one or two days of shooting before cleaning the sensor.
Is the blast of air the most used method, or are you using a liquid cleaner often. I've also read a discussion on the forum about the solution to either use or not to use.
Your comments and advice will be appreciated. Jim
I use the Eclipse method, the liquid and the 1.33 size swabs, and usually I get dust only when I change lenses out of doors. Otherwise, I set my aperture to f 16, I shoot the sky, I play it back on the LCD and use the wheel to zoom in as close as it goes and move the arrows around until I have seen the entire frame up close.
I was afraid the first time but I'm not anymore.
Mike
http://www.mikeadams.org
I am testing for dust and spots once a week using the defocused sky method and my Elmar 90. I find I need to clean about 1 to 1.5 times a month. My brother has just been on a photographic course in Namibia (sounded great - I would like to do it next year). It was part of the suggested routine, that everyone cleaned their sensor every morning. Most people were using an Artic Butterfly brush or similar plus blower every day and a wet clean every 3rd day. Sadly not a single Leica in sight on the course 100% Canon/Nikon.
Wilson
I am in aggrement with Mike...
I fist use a manual blower (Giotto-like) and then the Arctic butterfly. This usually removes all the dirt/dust about 95% of the time. For resistant specs, Eclipse is the way to go. Don't be afraid of Eclipse but PRACTICE your technique on a CD before hand and don't use too much fluid or re-use the brushes!!! ;):rolleyes:
Consider:
A = Degree of patience one has for spotting out dust spots in Photoshop using the clone/healing brushes
B = Degree to which is one is reluctant to clean the sensor
A > B = sensor need not be cleaned
A < B = sensor cleaning time
<G>
Cheers,
Sean
Has anyone tried using isopropyl on the sensor ( solvent recommended by Leica )?
Best Regards
Adam
The problem with isopropyl is it has too much water in it unless you get the reagent grade stuff. The easest solution to getting cheap sensor cleaner is to fly to Las Vegas and get your hands on some 195 proof Everclear vodka. We are talking about food grade ethenol with only 2 1/2 % water for six bucks a pint. Not only that you can take it back on the plane with you as a beverage! Try that with a 16 oz of Eclipse and you will end up in jail. Not to mention that a pint of Eclipse would cost around 10 K.
The other advantage of Everclear over anything else is you can use it to steady your nerves before you stick that swab in your precious M8.
Wrecks
Bought the M8 during the first week of November and haven't cleaned it yet. (This also included its flight back to Germany for re-fit!)
Yes, I am starting to see some dust but nothing I can't handle in PS. I plan the timing of each lens change to be as rapid as possible to avoid unneccessary time with the camera's mount open and unguarded.
-g
I had my first M8 from the beginning of November and have blown out dust from time to time as needed, and wet-cleaned it twice. It seems to need less and less cleaning.
The same for the one from early January, only I had to wet-clean that one just once.
got my m8 in nov. took a night of swabbing to get the grease off. ive wet swabbed 3 or four times since. artic butterfly about once every three weeks. i change my lens maybe 20 times a day. i learned here to turn the camera off when changing lenses to kill the static charge which was attracting dust-BIG difference ever since...B
I clean about every 1500 shots, typically when I notice dust in a shot. I'd guess 100 lens changes between cleanings. You need to decide how often based on your own needs and sensibilities.
--clyde
Consider:
<G>
Cheers,
Sean
LOL, yeah, put about as succinctly as I've ever seen.
I clean my sensor when I find too many spots in my images - which depends on what I'm shooting.
Got the camera in December, and have cleaned it once thus far. I have three lenses, and switch them around A LOT.
