M9 and external flash units
Al_OOF
My Bowens 800 and Elincrom units have always worked, with sync cable, with any camera. With Leica M9 they dont work.
Someone suggested me to reverse cable terminals (in the connector camera side)...
Any among you do have experience in connecting M9 to external flash units?
Many thanks for any advice
I use a PocketWizard in the hot shoe for my White Lightning lights. What sync cord are you using and how are you connecting it to your M9? When I connect to my Cheetah Light CL-360 via a PC sync cord I put a Nikon AS-15 in the hot shoe. No rewiring necessary.
I use this on the M9
and this to connect the flash unit
(mine has the 6.3mm RCA jack)
Have you ruled out one the above being faulty?
I use a similar setup occasionally (with PCB Einstein); it works just fine.
I tried with the same camera at the home of a friend of mine with his flash and with a different set of cable and adapter. It did not work with cable but only wireless.
