Mustafa Umut Sarac Posted June 2, 2014 Share #1  Posted June 2, 2014 Advertisement (gone after registration) Hello there ,     I have a Fed camera from 1954 , Leica II copy.And I have Bolex Kern Paillard Yvar 13mm C mount Lens for regular 8mm C8 Bolex Camera.  I want to use that lens on Fed 1954 - Leica II copy .  Is there any adapter for that combination and a source ? If not , is it possible to 3d print.?   Where can I find C mount thread details or cad file and Fed Leica II thread details or cad file  distance from lens back to film plane depth of Paillard lenses back sit on the adapter measurements ?   I have no digital camera .   Thank you ,  Mustafa Umut Sarac Istanbul Link to post Share on other sites More sharing options...
Advertisement Posted June 2, 2014 Posted June 2, 2014 Hi Mustafa Umut Sarac, Take a look here C Mount Bolex Paillard Lens to Fed Leica II copy,adapter or 3d print possibility ?. I'm sure you'll find what you were looking for!
jaapv Posted June 2, 2014 Share #2 Â Posted June 2, 2014 An 8mm C-mount movie lens on a 24x36 film camera? You will only get a small circle in the middle of the negative. The register distance is about 10 mm short, so you will not be able to focus to infinity, not even to 1 meter. Simply not possible. Link to post Share on other sites More sharing options...
oilman930 Posted June 2, 2014 Share #3 Â Posted June 2, 2014 The Bolex C8 camera did not use a C mount lens. The 8 mm cameras used a D mount lens. Link to post Share on other sites More sharing options...
gyoung Posted June 2, 2014 Share #4  Posted June 2, 2014 From memory the 13mm Yvar was the standard lens for the 8mm cameras, and d mount. Can't conceive of any use on full 35mm format. C mount standard for 16mm film was 25mm, and the wideangles 10 or 16mm, and would also be pretty useless on a 35mm camera.  Gerry  Sent from my GT-I9505 using Tapatalk Link to post Share on other sites More sharing options...
jaapv Posted June 2, 2014 Share #5 Â Posted June 2, 2014 Same conclusion for D mount. Link to post Share on other sites More sharing options...
