Albert Andersen Posted May 30, 2014 Share #1 Posted May 30, 2014 Advertisement (gone after registration) What does "max. exposure time" means in the Auto Iso setting? In the M camera is it min. exposure time, which in my mind is more relevant when you want to avoid camera shaking. Have I misunderstood something? Quote Link to post Share on other sites More sharing options...
Advertisement Posted May 30, 2014 Posted May 30, 2014 Hi Albert Andersen, Take a look here T Auto ISO. I'm sure you'll find what you were looking for!
pop Posted May 30, 2014 Share #2 Posted May 30, 2014 Ahem. The longer the shutter is open the more the camera might move during the exposure. Hence, you want to set an upper limit to the exposure time. Shorter times are indicated by greater numbers. Quote Link to post Share on other sites More sharing options...
Albert Andersen Posted May 30, 2014 Author Share #3 Posted May 30, 2014 Ahem. The longer the shutter is open the more the camera might move during the exposure. Hence, you want to set an upper limit to the exposure time. Shorter times are indicated by greater numbers. No, I want to set a minium exposure time e.g. min. 1/125 sec - how? Quote Link to post Share on other sites More sharing options...
pop Posted May 30, 2014 Share #4 Posted May 30, 2014 I don't understand. You want to set the exposure time to 1/125 or longer? 1/50 would be OK but not 1/250? What for? I do not think it can be done. Quote Link to post Share on other sites More sharing options...
jonoslack Posted May 30, 2014 Share #5 Posted May 30, 2014 No, I want to set a mininum exposure time e.g. min. 1/125 sec - how? Hi Albert exposure time is a reciprocal - so 1/125 is more than 1/250 . . . so setting 1/60 as a maximum exposure time means it will use 1/50, 1/125 1/250 etc. I hope this helps 1 Quote Link to post Share on other sites More sharing options...
Albert Andersen Posted June 2, 2014 Author Share #6 Posted June 2, 2014 (edited) Thanks Jono. I was a little bit confused because in M term for the same issue is "Min" shutter time. e.g. set to 1/125 sec the exp. time will always be shorter (1/125...1/250 ...a.s.o.) Albert Edited June 2, 2014 by Albert Andersen Quote Link to post Share on other sites More sharing options...
jonoslack Posted June 2, 2014 Share #7 Posted June 2, 2014 (edited) Advertisement (gone after registration) Thanks Jono.I was a little bit confused because in M term for the same issue is "Min" shutter time. e.g. set to 1/125 sec the exp. time will always be shorter (1/125...1/250 ...a.s.o.) Albert Hi Albert - doesn't it actually say 'Slowest Speed'? (that's on the M9 and Monochrom) Edited June 2, 2014 by jonoslack Quote Link to post Share on other sites More sharing options...
mjh Posted June 2, 2014 Share #8 Posted June 2, 2014 (edited) The M manual uses the term “maximum exposure time”, so there is some consistency between T and M. Edited June 2, 2014 by mjh Quote Link to post Share on other sites More sharing options...
pop Posted June 2, 2014 Share #9 Posted June 2, 2014 I press the SET-Button on my M, select ISO/AUTO; the M the offers a choice of OK Set Maximum ISO Set Maximum Exposure Time Quote Link to post Share on other sites More sharing options...
jonoslack Posted June 2, 2014 Share #10 Posted June 2, 2014 I press the SET-Button on my M, select ISO/AUTO; the M the offers a choice of OK Set Maximum ISO Set Maximum Exposure Time Hi Philipp - thanks for that - My M body is having a cla. Different ways of saying the same thing! Quote Link to post Share on other sites More sharing options...
tom0511 Posted June 3, 2014 Share #11 Posted June 3, 2014 and which one can you choose for the T? The Leica X doesn't allow 1/125 or 1/250 which are the settings I do need. Does the T allow 1/125 and 1/250 setting for max. exp. time in auto iso? Thanks a lot, Tom Quote Link to post Share on other sites More sharing options...
barjohn Posted June 3, 2014 Share #12 Posted June 3, 2014 Yes and even better, it has an auto setting that will automatically set to ½ x FL which is great for zooms! Quote Link to post Share on other sites More sharing options...
