AnakChan Posted May 27, 2014 Share #1 Posted May 27, 2014 Advertisement (gone after registration) Hi, I'm curious if anyone has any recommendations of soft releases that are thread compatible tothe M240? I tried the Match Technical bugs which were fine with my M9 but not on the M240 and saw the thread (no pun intended) that the M240 uses a different thread pitch - but that was talk about compatible cable releases rather than soft releases. Has anyone found a soft release that's thread pitch compatible to the M240? TIA Link to post Share on other sites More sharing options...
Advertisement Posted May 27, 2014 Posted May 27, 2014 Hi AnakChan, Take a look here Compatible soft release for the M240? . I'm sure you'll find what you were looking for!
K-Photo Posted May 27, 2014 Share #2 Posted May 27, 2014 http://hrr-manufaktur.de/shop/ These ones are designed for the new thread of the M240 / MM, but fit the older models, too. Link to post Share on other sites More sharing options...
kape06111 Posted May 27, 2014 Share #3 Posted May 27, 2014 I have talk with the guys from Match technical and they told me, that they are producing right now new Soft release compatible with M240 and that will be available until mid of june. Link to post Share on other sites More sharing options...
lanetomlane Posted May 28, 2014 Share #4 Posted May 28, 2014 http://hrr-manufaktur.de/shop/ These ones are designed for the new thread of the M240 / MM, but fit the older models, too. Thanks for this information, just ordered two (1 spare). The Soft Releases I had before kept coming unscrewed on my M so I hope these will do the trick. Cheers, Tom Link to post Share on other sites More sharing options...
Greg Gray Posted May 28, 2014 Share #5 Posted May 28, 2014 speak to the guys at popflash.com. i bought a couple from them and they fit perfectly Link to post Share on other sites More sharing options...
erudolph Posted May 28, 2014 Share #6 Posted May 28, 2014 Match Technical has a new version of their soft releases. The new ones have a rubber gasket on the stem, to help prevent loosening. The short stem version for the MMs and M240s is supposed to be arriving today. Link to post Share on other sites More sharing options...
AnakChan Posted May 30, 2014 Author Share #7 Posted May 30, 2014 Advertisement (gone after registration) Match Technical has a new version of their soft releases. The new ones have a rubber gasket on the stem, to help prevent loosening. The short stem version for the MMs and M240s is supposed to be arriving today. If you're able to share pix, that'll be greatly appreciated. Just curious. Link to post Share on other sites More sharing options...
erudolph Posted May 30, 2014 Share #8 Posted May 30, 2014 Hi Anak, I didn't see any images on the Match Technical website for the releases with the gasket, but if you go to the Popflash website and search out Match Technical, you will see many versions of the O-L release. I believe the ones for the 240 would be similar, but with the shorter stem. Link to post Share on other sites More sharing options...
hoppyman Posted May 31, 2014 Share #9 Posted May 31, 2014 Tom Abrahamsson of Rapidwinder.com in Canda produces a couple of versions (normal and mini) in different colours. I got mine directly from Tom and they fit perfectly. There is a list of dealers who carry them on his website too. Link to post Share on other sites More sharing options...
K-Photo Posted June 10, 2014 Share #10 Posted June 10, 2014 The Soft Releases I had before kept coming unscrewed on my M so I hope these will do the trick. And are these ones fitting better ? Link to post Share on other sites More sharing options...
HKFEVER Posted June 16, 2014 Share #11 Posted June 16, 2014 And are these ones fitting better ? Yes, better but not that much. Link to post Share on other sites More sharing options...
erudolph Posted June 16, 2014 Share #12 Posted June 16, 2014 I am really enjoying the new short-stemmed soft releases from Match Technical. They have a rubber flange to help keep the release from unscrewing, though Tim warns that it's still possible for them to loosen from friction against the side of the bag, etc. And they have some sort of rubberized coating that I like the feel of. Link to post Share on other sites More sharing options...
AnakChan Posted June 23, 2014 Author Share #13 Posted June 23, 2014 I am really enjoying the new short-stemmed soft releases from Match Technical. They have a rubber flange to help keep the release from unscrewing, though Tim warns that it's still possible for them to loosen from friction against the side of the bag, etc. And they have some sort of rubberized coating that I like the feel of.Assuming you'll never take it out, would you consider using Loctite? Link to post Share on other sites More sharing options...
erudolph Posted June 23, 2014 Share #14 Posted June 23, 2014 For me, no, I wouldn't use Loctite. Link to post Share on other sites More sharing options...
ayewing Posted June 23, 2014 Share #15 Posted June 23, 2014 As I use a cable release sometimes I would not use Loctite . Link to post Share on other sites More sharing options...
