Leica CL portraiture
crow
Is the Leica CL capable of shooting nice sharp portraits, using the Elmar C?
I mean that the 90mm rectangle is too small to be able to focus precisely.
Isn't a larger RF base like the M5 easier to focus?
Plus the M series but the CL take vf magnifiers. The Cl I am going to have to improvise to make an SLR magnifier fit on the CL viewfinder window frame. There is no magnifier for the CL, I believe the VF rectangle window is about 17-18mm long.
I think the Elmar C is better than people realize. I have no trouble focusing on the CL, even wide open - since it is "only" f4 the CL can handle it. As for sharpness, here is a 100% crop from my Elmar C wide open on my M9 - the first test shot I took when I got it. (The EXIF indicates it was stopped down, but the camera was facing a bank of lights that confused the camera - the lens was at f4.0.)
that's a nice crisp shot.
I haven't used any other 90mm lenses other than the 9cm, and the C is sharper, no doubt about it. However you've used it on the M9, not the CL. My question is regarding the CL's shorter base AND SMALL 90mm frame lines/ rectangle in the viewfinder.
It's true this shot was on an M9, but it shows the lens capability better than a shot on film. I'd never try an enlargement to that degree from film. While I got the lens to use on my CL, I don't have any digital files acessible from it right now.
Remember though, the Elmar C was designed for the CL, and Leitz always said its focus might not be reliable on M models.
  • 4 weeks later...
Also have a 9cm which will fit with an adapter on the M5 or 6.
And will be able to compare the two.
Will force fit a magnifier and see.
What aperture do you take pictures at? f5.6? Focussing should not be a problem.
My first 90mm was the f4 Elmar from the 1950s and quite good on film with my CL. I replaced it with an f2.8 Elmarit from the 1960s or so, which was sharper but bulkier. I replaced this with the later TeleElmarit f2.8, which was the sharpest yet and lighter than the Elmarit. I never had a problem focussing it.
I use it now on my M9 (I sold my CL).
I expect the modern f2.5 90mm Summarit would be better still but more expensive. Depends on your budget.
Philip:)
No need for a magnifier, unless I find one real cheap.
Got a Leica M5 and will keep the 90 Elmar C on it all of the time. For wide angle shots, the CL will be more than fine with the 40/2 Summicron. Much bigger viewfinder with the M5, makes it easier. Don't know how it will work with the C lens, since it is made for shorter RF base. Will see.
The CL is more than capable of taking very fine photographs after all it's just a black box with a shutter. The shorter distance between rangefinder windows could compromise focus accuracy but not to a major extent especially with slower lenses such as the 4.0/90 Elmar-C. I've used that lens a few times borrowed from a friend) and also use the 4.0/90 ZM Tele- Tessar on it with no problems. Having said that I'm not sure Id be trying something like a fast 75 or 90 (or 135) wide open as that may well challenge the limits of the rangefinder.
The 90 Elmar -C is a very nice lens, lower contrast and not as quite as sharp as newer lenses so is more flattering to subjects for portraiture.
Yes,
it won't show wrinkles like a Tele Elmarit M would.
However, i seem to be moving very slowly as I first got a 9cm/4 Elmar lens which is even more soft than the Elmar-C. I managed to get a CL viewfinder magnifier.
I will try both lenses focusing with the aid.
Then I will compare to the M5 I just got.
I will find out :
if the CL lenses work OK with a larger RF base such as the M5's,
and if the Elmar C is sharper on the M5 than it is on the CL.
But also if the 9cm/4 is sharper on the M5 as well.
I am leaving the 40 Summicron on the CL so I don't have to change lenses while on the move but also find out if the Summicron 40 works well on the M5's RF base. This will take some time though.
Yes,
I will find out :
Well, I can answer your questions as can many on this forum. It's pretty easy.
Lenses meant for the CL have a slightly different RF coupling than M lenses and may not couple accurately with an M. M lenses work fine on a CL.
Lens performance does't change with a different body.
A CL will shoot portraits if you can.
A CL will shoot landscapes if you can.
I would do anything an M will do with a CL. In fact I do. I'm staring at one right now.
Pretty easy.
Phil Brown
I don't think I am interested, or anyone else in this forum, in what you could be looking at in a specific moment.
I am not sure I got convincing answers as there are people who claim Leica Cl lenses were only said to be not compatible with other M bodies because they came out cheaper than the rest of Leica expensive lenses.
Not that you don't have a point, as it is logical that because of the different RF sizes there might be problems of incompatibility. Why then people claim CL lenses match other M bodies?
I have to see that with my own eyes. Takes time. Got a full time job. Time goes by so fast.
Yeah,
but have you tried them your self?
I use both the 40 and 90 on various M models including M9, and have not seen any focus problems. I have heard many others report the same, and in spite of Leica's notice have not heard reports of real problems.
Perhaps Leitz mainly wanted M owners to buy more expensive lenses.
By the way,
I got a diopter correction attachment especially made for the CL viewfinder.
I am not near sited so it doesn't work, but I have an idea.
I will substitute the glass with a new one that will be simply a magnifying one.
Does it matter how far away it mounts away form the real VF glass?
Will it work?
Purpose is to have a larger double image when focusing.
