Leica M: Playback Mode- with EVF- a question
jaques
I find it a bit annoying when I play back an image with the EVF installed- and it plays back first in the EVF so that I have to press the button to turn off the EVF before I can see the image on the LCD screen. I had thought that this would be a setting I could change: 'only play back on LCD'. However looking through the menu I can't see an option to select this. I am guessing you can't? Or am I missing something?
if you have review set to off- and you press the play button- does it play on the LCD?
EDIT: Dang- just tested- and the answer is NO. Bit of a shame... I guess the chances of a firmware fix/enhancement are next to zero?
It would be handy, I too often find myself looking at a black screen after pushing play. I guess the reason is that play and review are basically the same module.
I have auto review set to hold shutter button, which allows me to bridge the blackout of the EVF after taking an image. Now it only freezes the EVF display briefly which somehow seems more logical.
Leica, as usual, thinks it knows best - that the same display device should be used for focussing/framing and image playback/review. The Leica (or should I say LFI) acolytes are happy to defend that position.
Truth it, it would be a perfectly reasonable operating mode to use the EVF to continue to display the live view output after a shot is taken and display the image just taken on the LCD. In that way, the camera in Live View mode would mimic an M9, even be an improvement on it with the higher resolution LCD.
There may be a hardware limitation which prevents different video output to more than one device at the same time which shows short-sightedness in the hardware design.
Perhaps the next generation Maestro chip-set is better able to meet this need, though I'm not holding my breath.
Who is defending here? All posts express a wish for a different solution and annoyance at the present situation. No reason for a nasty fling.
Yes, I agree—image playback must not happen in the EVF but always on the rear screen.
Generally, there are some really silly and annoying quirks in the design of the Leica M (Typ 240)'s user interface. Automatically playing back the picture always on the same device that's used for live-view is just one of them. The tiny red-on-black font for selecting ISO and other things is another. The most stupid things are the useless Auto-ISO function—and the inclusion of the the time-zone setting in the user profiles ... so when traveling across time zones, you cannot simply adjust the camera's time-zone setting but you must update all your user profiles.
I find this quite annoying as well. I don't use the EVF very much but it will soon change when I get the R-M adapter. Its unpleasant to review images through the EVF :(
And so is the blackout - The EVF should freeze the image during processing whatever the setting of playback (which should be on the LCD by default).
The playback mode with EVF and options needs re-examining.
Ideally I'd like to have no playback in the EVF but have the option to have auto playback in the LCD for a chosen time. As things stand I have playback set to off, but then have to turn off the EVF before the Play button will work and display the image on the LCD.
How many beta testers were there?
I think this was just the easier way to implement it: just switch the output from one display to another, and the EVF has been "implemented".
I won't be surprised if both displays could not be driven with simultanous independent outputs.
Digital design and firmware are not Leica's forte.
