I had the same thought.
It looks like the process has started.
How old is that camera?
The M9-P is just over two years old, has mainly been used as a back-up camera for my M240, has around 800 actuations and has never been wet cleaned. There are a dozen or so of these marks.
How large percentage of M9 class cameras is affected by the corrosion issue, and what is the likelyhood that a hitherto unaffected camera will develop the corrosion issue? Has this been determined yet, or has Leica said anything about that yet?
Depends what you mean by "affected". Any camera with the sensor type in question (M9, M9-P, M-E, MM) is vulnerable to corrosion at humidity levels above 70% RH. Depending on how much humidity it is exposed to, the camera will develop the problem sooner or later.
Thanks. Do you have by chance a similar image from an earlier date and small aperture?
I am ever more doubtful about the "cleaning" explanation. How long is the sensor actually moist? Seconds or less. For a corrosion process to take effect I would imagine that a more long-term influence would be needed. i.e. continuing humidity. Maybe salt air in the neighbourhood of the sea, some thing like that.
I also very much doubt it, especially because there have been so many cases mentioned in this thread of sensors showing this problem, which have never been cleaned.
I've compared earlier similar shots and yes, there were similar but fewer marks a year or so earlier.
What I have done is use the earlier shots, where the problem is seen to first appear (on a particular spot in the sensor), to make the case that my camera, now out of warranty, was suffering the problem within warranty (the date of the earlier shots).
Send Leica a CD with the relevant RAW files as proof.
I thought this might be helpful to you, too.
Thanks. I think it would be very instructive if you loaded both images into Photoshop cropped the same area and document and post a comparison. TIA.
Maybe it is even the other way around, that a certain type of sensor contamination (Pollen? oil? maybe even miniscule drops of sweat fro the hands when changing lenses, etc.) will initiate corrosion when not cleaned off.
It is very suggestive that it starts off as "dust". Who knows...
Ok, here's the shocker, I've now gone back into photoshop and had a good look at several blower brush sensor cleaning test shots I made in August 2013 which clearly show many of these weird circular rings with central dark spots and compared them with shots made a week or so ago and the more recent shots show far fewer of these marks although they do appear larger.
What the hell?
My theory since the beginning was that it's oil from the shutter. That's how the spots look like first then if not cleaned promptly they become unremovable and develop the characteristic bubbly look.
My M240 sensor got a lot of oil spots in the first weeks of use. They looked exactly like the M9 spots but I easily removed them with wet cleaning and now they've stopped completely.
Edited by edwardkaraa
What the hell?
It depends on the lens used and the aperture. Also the spots are air bubbles under the coatings. Sometimes they move or consolidate into a larger bubble.
What the hell?
Many thanks. I would love to see the image comparison.
Please, let's follow this train of thought wherever it leads!
Could you also give us the relevant lens parameters.
edwardkaraa makes a pertinent point.
Thanks again.
Edited by k-hawinkler
Thanks again.
I'm going to redo the test tomorrow and will post a comparison of the resulting shot with that of one from July 2013. I'm beginning to think that as Edward has said these circular ring type marks may be air bubbles.
Well, they can hardly be oil, if you have never wet-cleaned the sensor...
Can you show an example of the same spot, before and after?
No, none of them look like oil spots. These ringed circular marks with dark central spots and pale halo are unlike anything I've encountered before. I'll hopefully post the older shots vs newer shots comparison tomorrow.
Repairs
Not that Leoca can or are willing to even consider this, but however, I just had an experience with Canon.
I dropped my beloved 70-200 on the pit lane cement floor at Daytona a few weeks back.
So a pro nearby told me where to contact Canon-CPS.
They have various levels of service available for pros or serious amateurs.
The levels are based on a point system which corresponds to various bodies, lenses and accessories you already own.
If you do not make the first level of cutoff you do not get a service discount nor priority turn around.
The Gold level cost me $100 which is the annual fee for that level of service which includes a 10% discount on all work performed. They promise the repaired item within 3 business days once you email confirm their repair cost which they email to you and provide a credit card which they charge at the conclusion of the service.
My lens needed an AF motor and lens hood. They emailed me the cost within one business day of receipt of the lens. I was astonished after having Leica send me a letter maybe at best one month after receiving a lens for CLA even though I put on my repair sheet to email me all correspondence.
The lens came back like new round trip in less than one week! I must say I am now spoiled.
I had a large Leica dealer send in my 180/2.0 R lens to NJ and it took them 7 months just to blow some dust out of it.
Leica should contemplate joining the real world of camera repairs.
