Best finder for CV 15 on M8
prav66
I'm about to pick up a CV 15/4.5 & was researching the appropriate finder. I'm leaning towards the Zeiss 21mm finder (cost increase over the CV one seems worth it).
However, seeing as the crop factor on the M8 is really more a 1.25x, the view of the 15mm corresponds more to a 19mm view so I'm wondering if the 21mm finder is too tight for this lens.
I believe Zeiss is coming out with a 18mm one along their 18mm lens soon & this seems to fit the CV lens better. At least with calculations on paper.
I have no way of of course of really knowing short of buying it & trying it. Any users out there who can provide input on this?
Much appreciate it..
Again my thanks to this forum for the incredible feedback and generous assistance of all its members...
Prav,
The crop factor of the M8 is 1.33, so a 21mm finder is what you need.
I am using the CV15 with the 21mm CV finder.
No problems at all - good visibility of the frame lines and good accuracy in terms of capture preview. Recommended.
Peter
I use the CV 21mm finder on my M8 with the CV 15 and it is certainly adequate. The finder came with the CV 21/4 that I also use so no point in buying another 21 finder.
There may be different versions of the Leica finder. The ones I checked out, looking to buy for my CV15, we so soft either in the centre (!) or at the edges, that I decided just to wait until I buy my CV21 with finder, and then use that.
My CV 21 finder, which I use with my CV 15, is horribly crooked. I can't get straight horizons. I don't know if anyone else has a problem or if I got a lemon.
There's some barrel distortion but the frame lines should not be crooked.
I was about to order the CV21 finder -- now you have me wondering !! :eek:
I own the Leica 21 external finder and a Ricoh 21/28 finder and lately I have used the Ricoh and do like it. Some say its 3:4 but so far I feel its working pretty good and allows me to use it for the cv 15 and the Leica 21mm , and its a nice smal size which - IMO - fits the character of a Leica M camera.
cheers, >Tom
the different thing in my experiecne is to level the camera correctly
Gary, funny you should mention that. I got one recently (the CV21 finder) and everything I shot was about 5 degrees off axis. Turned out that the glass element in the finder was installed improperly. Sent it back and got one with correctly adjusted framelines.
SP
I have exactly the same problem with my CV 21mm finder - it's about 10 degrees 'off', and all of my trial shots with the M8 and a CV 15mm have horizons sloping to the right.
It's going back to Robert White tomorrow for an exchange.
