M-E Sensor Damage
Philjh
These marks appeared on my sensor recently.
Not caused by cleaning.
They look like scratches but I have no idea how they happened.
Could some debris have got behind the shutter?
The marks are very uniform.
My dealer will be sending the camera to Solms, I guess it will need a new sensor.
Has anyone any ideas how this could happen?
It is actually quite hard to casually scratch glass, the sensor covering, so cleaning it would have been the simplest thing to try before sending it to Solms. Given M9/M-E sensors spit oil and bits onto the sensor when new it's most likely to be loose debris or streaks of oil.
Steve
I used a Visible Dust swab with Sensor Kleen fluid and Dust Aid sticky pad to no avail.
I thought it might be a hair but when you look at the sensor it does seem scratched. My worry is that it is a sensor fault that may get worse so it seems best to get it checked out.
My dealer reckons it'll be repaired under the Passport warranty.
The M-E will be in Solms on Tuesday for surgery.
It was quite hard to part with the camera.
  • 4 weeks later...
I heard today that Solms are replacing the sensor, no other details.
Well I've joined the replaced Leica sensor owner club, somehow I knew I'd be getting a new sensor at some point but after 6 months ownership is a bit soon. Still I knew what I was taking on when I bought the M-E and wouldn't be without it, except when it's in Solms!!
