Tri-Elmarit Posted September 22, 2013 Share #1  Posted September 22, 2013 Advertisement (gone after registration) ARW5 says:  I noticed that you can control ISO with Leica Digital Capture software  Does camera remember that ISO setting after you unplug it from USB cable ? And when I turn my camera off and turn it on again... is the ISO same ?  Can you set AUTO ISO on with M8.2 with software controlled ?  I suppose it is not possible to format memory cards Leica Digital Capture software controlled?  Im just thinking is it poosible to still use M8 or M8.2 with broken LCD Link to post Share on other sites More sharing options...
Advertisement Posted September 22, 2013 Posted September 22, 2013 Hi Tri-Elmarit, Take a look here Leica M8 , M8.2 and Leica Digital Capture software. I'm sure you'll find what you were looking for!
lct Posted September 22, 2013 Share #2 Â Posted September 22, 2013 Does camera remember that ISO setting after you unplug it from USB cable ? And when I turn my camera off and turn it on again... is the ISO same ? Yes if Leica Digital Capture (LDC) works on your computer. It does on my Macs with OSX 10.4 but not with OSX 10.6 for instance. ...Can you set AUTO ISO on with M8.2 with software controlled ?... No but you can save a User Profile in the camera for your Auto ISO settings and choose this same profile with LDC afterwards. ...I suppose it is not possible to format memory cards Leica Digital Capture software controlled?... No but you can format your cards in your computer with SD Formatter and use it as is in your M8 or M8.2 with no problem i know of. Link to post Share on other sites More sharing options...
