hsujy Posted September 18, 2013 Share #1 Posted September 18, 2013 Advertisement (gone after registration) Any one know how to use Leica 20cm f/4.5 Telyt telephoto lenses for Visoflex on Leica M? I'm looking for adaptors that can fit this lens on Leica M type 240, without using the visoflex system. Link to post Share on other sites More sharing options...
Advertisement Posted September 18, 2013 Posted September 18, 2013 Hi hsujy, Take a look here Adapter for Leica 20cm f/4.5 Telyt lense for Visoflex on Leica. I'm sure you'll find what you were looking for!
gyoung Posted September 18, 2013 Share #2 Posted September 18, 2013 I use my 200mm/4 Telyt on Nikons via a Visoflex to Nikon F adapter, you could add a Nikon to M adapter to that. There was also a Leica adapter tube to put the Telyts directly on to the screw mount bodies, which you colud use with an L39 to M adapter ring, it had a shoe mount on it for a wire frame type finder. (Wont fit the last type 280s though). Cant remember the code for it but a bit of research in the Wiki might find it, or ion due course one of our Visoflex experts will no doubt tell us Gerry Link to post Share on other sites More sharing options...
UliWer Posted September 18, 2013 Share #3 Posted September 18, 2013 Originally there was the TXBOO-Adapter: http://www.l-camera-forum.com/leica-forum/leica-sammler-historica/97081-kaviar-10.html#post1542273 http://www.l-camera-forum.com/leica-forum/leica-collectors-historica/211981-txboo-numbering.html#post1902506 It should work with the M without problems - though you can't use the spezial viewfinder TUVOO as shown on the first photo, since the modern M-bodies are higher than the M3. Therefore you need the higher accessory-shoe shown in JC's photo. The TXBOO is rare - the higher accessory-shoe is extremely rare - , so you won't have much chance to find it on the second hand market. The new Novoflex adpater for Visoflex lenses (LEM/VIS https://www.novoflex.com/index.php) should work as well; if your lens has screwmount, you need a screw-mount to M-adapter on top. Link to post Share on other sites More sharing options...
