Late Build Dual Range 50mm question (1969)
Sloanfiske
On the wiki Serial Nos. list the info in (parentheses) like (SFK-DR-chrom) was/is added to Puts data when I find at least one lens in a batch of that type for sale.
I think Luigi+others have said is, if a 50-DR occurs in batches 2278751-2279750 and 2356301-2358300 (or other higher batch), then that lens would be built with 7 elements rather than 6. Perhaps we should add "and 7 /4 (DR)" to Number of lenses /groups in the Summicron (II) data?
Also, do we agree that 2269251-2270250 batch is the first for Summi (II)?
And what is the difference between 11 817-black - 11 819-black and 11 318 (DR) - 11 918 (DR) ?
Thanks, Tim
  • Replies 44
  • Created
  • Last Reply
Thanks, Tim
My 11817 purchased in 1969 is from 1968 production, and is the newer anodized aluminum 6-element version.
In 1969 you could also get the 11117 black Summicron, which was the black version of the older "rigid" mount lens (11118). Both were then the same price ($171).
Thanx TomB,
Now you've identified another 50summi order no. 11117 :-) will the complexity never cease! Aluminum or plated brass?
Summi (II) were aluminum - does anyone know if the late 7/4 DR versions (built during Summi {II} era) were aluminum or chromed brass?
Tim
Thanx TomB,
Tim
Judging from pics, I'd say chrome brass.
Summicron (II) f= 5 cm 1:2 is now revised (also w/ ELCAN lens shown)
Beware: it's true that Elcan opening is up to F.:2, but speaking about the lens design it's not a Summicron, is a different thing in itself. The project was a hybrid/evolution between Elmar and Colorplan: at the end we have an air spaced four elements lens with highly sophisticated glass elements (ex: LaK9, Leitz glass 672460).
kind regards.
That explains why its shape is different. Looks like we need to add a page for Leica lens #179 :rolleyes: Thnx sabears + luigi
Where can I find tech specs for ELCAN 50 f2 :confused:
Tim
Lager depicts the vey first one (276-00001) : a four elements design, based indeed on a projector (Colorplan) lens... seems that Summicron was "too good" for US Army specs, so Ontario built a cheaper lens, probably around 300+ were made, sold also in the "civilian" market with the "civilian" KE7A.
  • Name - ELCAN f=2 5 cm 1:2
  • Leica Order No. - sold w/ KE-7A see M4
  • Production era - 1972-1974 - 515 lenses
  • Type - This lens came w/ the Leica KE-7A which was supplied to US Military by contract. Only 460 sets were produced for this purpose while another 55 were sold to the public. The lens has only air spaced elements and is thus suitable for extreme use. It has non-cemented glass, less problem in a high temperature range and nearby explosions.
  • Lens mount - M-bayonet
  • Number of lenses /groups - 4 /4
  • F stop range - f /2 - f /16
  • Diaphragm setting /type - 10-blade
  • Inscription - ELCAN f/2 50 MM 276-0XXX
  • Designer - Walter Mandler
kinda thin - can we add any more?
No one has tech specs for ELCAN 50/2?
I don't have access to Puts. He's taken down all his old on-line stuff and I don't have Lager's book. Can anyone add
  • Closest focusing distance -
  • Smallest object field -
  • Angle of view diagonal -
  • Accessories -
  • Materials - Anodized aluminum, lanthanum infrared-absorbing glass and high refractive optical glass as used for heat control in Leitz projectors.
  • Weight -
-Tim
The closest focus distance of the ELCAN 50 f2 was 2.5 feet (scale was feet only, no surprise....). Here is the optical schema (Courtesy of Marco Cavina)
Worth noting that a prototype in collapsible mount was made (Elmar style), with the same formula designation (276) , while another Elcan 50 prototype had a formula identified as "132", and looked more like a standard Summicron 50 fixed mount... maybe an evaluation for US Army tender.
The very important thing to emphasize is that the prototype, which is not like an elmar aesthetically but it is a thing in itself, was made ​​in Germany and not in Canada, indeed it is engraved "Made in Germany" on one side.
kind regards.
Found in my archives this pair of pics of the Elcan chrome... don't have the source (maybe an old auction... :confused:) Looks a std. Summicron, indeed... with the removable lenshead as usual.
This is "The thing" (better photographed on J. Lager book for sure!), photographed something like 15 years ago in Usa. Sorry for the quality. A difference with others prototype lenses that were done in some (few) specimens: only this was made, so it's the only in existence.
cheers.
