SD Card Not Detected
AceVentura1986
My Equipment: M-E w original FW, Panasonic Gold SD in 32gigs, iMac running Lion OS.
Last night, I installed the card after downloading into Lightroom and the camera failed to recognize the card. It warned that there was no card installed. I removed it, turned the camera off, reseated the card and turned the camera back on, same warning. I the removed the card, reinserted in the iMac, selected the icon and ejected again. This time everything worked. Note, although I don't specifically remember ejecting the first time, it is my practice to do this every time so I'm pretty sure I did it the first time.
Any thoughts?
RV
I had a Sandisk card that the M9 refused to recognize, and no amount of reformatting helped. Three years later that card still works fine in any other camera I use it in other than the M9. So even if that card works for you now and you do reformat it I would still not rely on that card as my only one.
