Leika38 Posted May 22, 2013 Share #1 Posted May 22, 2013 Advertisement (gone after registration) Just sharing. I've tried all the others - Sandisk Extreme Pro, Kingston, Toshiba, etc. Laggy and takes more than 2 seconds. With the Samsung SD Plus, my Typ 240 starts fast, in less than a second. The 16GB costs about USD 19.70. Hope this helps. Link to post Share on other sites More sharing options...
Advertisement Posted May 22, 2013 Posted May 22, 2013 Hi Leika38, Take a look here Leica M Typ 240 - Fast startup with Samsung SD Plus. I'm sure you'll find what you were looking for!
lct Posted May 22, 2013 Share #2 Posted May 22, 2013 Did you press the shutter release before switching the camera on to count the time? Just curious as my class 10 Mustang, Transcend and Sandisk don't go faster than 2 seconds and a half roughly Link to post Share on other sites More sharing options...
k-hawinkler Posted May 22, 2013 Share #3 Posted May 22, 2013 Just sharing. I've tried all the others - Sandisk Extreme Pro, Kingston, Toshiba, etc. Laggy and takes more than 2 seconds. With the Samsung SD Plus, my Typ 240 starts fast, in less than a second. The 16GB costs about USD 19.70. Hope this helps. Thanks. How many shots can you fire off before the M240 slows down? Link to post Share on other sites More sharing options...
Leika38 Posted May 23, 2013 Author Share #4 Posted May 23, 2013 Did you press the shutter release before switching the camera on to count the time? Just curious as my class 10 Mustang, Transcend and Sandisk don't go faster than 2 seconds and a half roughly Switch on, then press shutter release. Picture taken in less than a second. Interesting thing is that I see the frame lines and shutter speed numbers the moment I switch it on, unlike when I use the other SD cards. Just to be sure, I'll go buy another same SD card to see it's just as fast. Link to post Share on other sites More sharing options...
Leika38 Posted May 23, 2013 Author Share #5 Posted May 23, 2013 Thanks.How many shots can you fire off before the M240 slows down? You're welcome. It starts fast, so I can start shooting in less than a second. Link to post Share on other sites More sharing options...
lct Posted May 23, 2013 Share #6 Posted May 23, 2013 Switch on, then press shutter release... Would you mind to press the shutter release in the first place and switch on afterwards? Link to post Share on other sites More sharing options...
StephenPatterson Posted May 23, 2013 Share #7 Posted May 23, 2013 Advertisement (gone after registration) And let us know how many continuous shots before the buffer slows the fps rate? Link to post Share on other sites More sharing options...
lct Posted May 30, 2013 Share #8 Posted May 30, 2013 ... How many shots can you fire off before the M240 slows down? Eleven shots (DNG only - DNG compression on - Empty card). Same with my other class 10 16 GB cards (Mustang, Transcend, Sandisk). All formatted through SDFormatter. Link to post Share on other sites More sharing options...
lct Posted May 30, 2013 Share #9 Posted May 30, 2013 Would you mind to press the shutter release in the first place and switch on afterwards? No problem dear LCT, your wish is my command. Result: about 2 seconds and a half like with my other class 10 16 GB cards (brands above). Link to post Share on other sites More sharing options...
