400mm 6.8 telyt/visoflex
innerimager
I picked up this most interesting and fun to shoot lens yesterday. A 2 element piece of simplicity with a push/pull focus used with a visoflex. It's most satisfying to shoot, quite light, has a shoulder support as well. And...yes you can get sharp images without AF let alone IS/VR on the M8 with a equivalent 520mm view. This was iso 640, 1/2000, 6.8. best....Peter
  • Replies 40
  • Created
  • Last Reply
I love this lens...;)
DMR, 6,8/400mm
very easy to handle and great performer...
regards,
Jan
Nice shots! Really cool. Question: Do you (or does anyone else) have a photo or two of somebody when he or she is using the rig to get shots like these? I've seen images of the rig itself--but not of the rig in use. Thanks --Will
Thank you Will, (if you meant mine, as Jan's are killer shots aren't they?). Don't have any shots like your asking for, but next time I'm shooting with a buddy I'll get one for you. best...Peter
I meant all of the shots in this thread--thanks. That would be great! I'd really like to see what the rig looks like in action! -Will
This is a picture a photographer send me by email. He was watching me doing the birdshots...:D .
regards,
Jan
Has anyone experience with using a TXBOO extension tube (in place of the Viso) & a Telyt on any M body?
I would imagine it would be near impossible to focus without a Viso
the Viso is a bit of a Rube Goldberg solution and I am amazed at the images Peter and Jan got with theirs ...wonderful clarity
I am curious as to which adapter is needed for the 400 Telyt and also for the 200 Telyt
my local shop has a 200 Telyt in stock at a good price & I just got a Viso III with bellows & the 135 Tele Elmar
I am tempted to expand my Viso experience ...my results so far with macros have been very encouraging
Can only guess at focus then. Or just focus at infinity. I considered this, but better just use an extension tube, cheaper
regards
regards,
Jan
Dear Jan
Without the shoulder (gun) mount? I am actually afraid use in US. Can get shot! esp if aim at a plane near airport.
But looks like you just hold naturally (loosely speaking, of course :-)
Wonderful shot. Just received mine. will be testing on both M8 and DMR since I have both tubes in the set.
Regards
jaap- do you still have it?
Jan- Fabulous shots! It really is a great handling lens, you show what it can really do. best....Peter
No; I have the Noflexar 400/5.6 on Pigriff C It is basically the same lens, but better corrected and faster, as it is a three-element achromat, as opposed to the Leitz 2-element. Built by Leica as well.
I believe the 400/6.8 has significant curvature of field. I can certainly see that with shots taken with an R9 (same lens head as the M version). I was told Leica designed it this way to give an apparent increased depth of field as objects in the bottom of the field tend to be closer, I would take that with a marketing pinch of salt though. ;)
Bob.
Bob.
It is just the excuse. The original two-element Leica 400/5.6 REALLY had curvature of field, so Leica went to 6.8 to get it within bounds. As it is it is fine for the application but don't start shooting newspapers or brick walls with it. The original 5.6 design was upgraded for Novoflex by adding a third kitted element, which was even more effective than the Leica edition, but made the lens heavier (not too much though) and a whole lot more expensive. Novoflex had their lens heads produced by Leica up to the mid-nineties, when production stopped, as popular perception made AF lenses preferable to the Novoflex squeeze-focus mount and the Leica slide-mount. There are Leica heads on Novoflex mounts around as well.It is still more exact than most AF systems though- and as quick. Both the Leica and the Novoflex lenses are still very good perfomers, especially with the edges cut off by the M8.
Arthur,
You need and OUBIO or 16466M adapter to use the later Telyt 200 f4. I am not sure about the 400 on a Viso II or III.
Wilson
Arthur- No adapter needed for the 400/6.8 and I assume the other telyt telephotos. Just mount to that visoflex III and go have fun! best.....Peter
QUOTE=gogopix]Dear Jan
Regards
Hi Victor,
yes I only use the lens without all..It is very easy to hold and looks not so "dangerous"..
regards,
Jan
No! For the 200, 280 and earlier 400/5.0 you need the adapter OUBIO # 16466.
It is plentiful on the used market. Leicabeimeister has one and Cameraexpress has several, to my knowledge, but they are all over.
