philipus Posted April 26, 2013 Share #1 Â Posted April 26, 2013 Advertisement (gone after registration) I'm looking to buy a B+W ND filter but have trouble deciding whether I should get a 3-stop or a 6-stop filter. Â Has any of you faced a similar conundrum? If so, I'd be very grateful for how you reasoned in coming to a decision. Â Cheers and thanks in advance Philip Link to post Share on other sites More sharing options...
Advertisement Posted April 26, 2013 Posted April 26, 2013 Hi philipus, Take a look here ND filter 3 or 6 stops?. I'm sure you'll find what you were looking for!
250swb Posted April 26, 2013 Share #2 Â Posted April 26, 2013 It depends what you want to do with it. If it is to increase the exposure when using a fast lens wide open I use a 3 stop filter. But if it is for using along with a tripod to make water look smooth and milky I would say a 6 stop would be best. Â Steve Link to post Share on other sites More sharing options...
Tinchohs Posted April 26, 2013 Share #3 Â Posted April 26, 2013 Along these lines. Â (1) Do ND filter significantly impact image quality? (2) Which brand would you recommend for a Leica MM to be able to shoot wide open during the day? (3) Do color filters affect image quality? (4) Again, any brand recommendations for yellow filters? Â Â Thanks so much. Link to post Share on other sites More sharing options...
spydrxx Posted April 27, 2013 Share #4 Â Posted April 27, 2013 I went with a 3 stop B+W ND filter a couple of years ago and have been pleased with that choice. I've never found a need in my work for anything greater. Link to post Share on other sites More sharing options...
jdlaing Posted April 27, 2013 Share #5 Â Posted April 27, 2013 Look at a Heliopan Variable ND filter. Link to post Share on other sites More sharing options...
MT710 Posted April 27, 2013 Share #6 Â Posted April 27, 2013 Finally I went for a 2 stop B&W only for the purpose of compensating in sunny situations, when a 400 ISO film is in the camera and I want more options of aperture and time. I hardly use it, though (and I have no Summilux or Noctilux I would want to use wide open ). If I was to buy again, it would be the 3 stop. Â Michael Link to post Share on other sites More sharing options...
Paul J Posted April 28, 2013 Share #7 Â Posted April 28, 2013 Advertisement (gone after registration) I use both the 3 and 6 stop. They are both very useful depending on the lighting conditions and application. Where are you based? In the UK, for example, you would probably get more use out of the 3 stop. Â 3 stop you get the added benefit of using higher shutter speeds. You need the 6 stop with flash as you're tied to 180th sync. Also know that the 6 stop has quite a strong colour cast. But the warm tone is very pleasing and I like it. Link to post Share on other sites More sharing options...
philipus Posted April 28, 2013 Author Share #8 Â Posted April 28, 2013 I'm mainly in The Netherlands and Sweden so weather-wise it'd be similar to the UK, I guess. Â I also read that 6-stop filters have a warmer colour cast but I think I wouldn't mind that, actually. I've been thinking if 6 stops would be too much but I think it might be ok. Â B+W has two versions of the 6-stop, single and MRC-coated. Reading around, it seems MRC filters 1) are easier to clean due to the increased resistance, and 2) let more light through. Easier to clean is a good thing, but not really super necessary I would think. To let more light through seems to contradict the purpose of an ND filter. Â My current thinking is therefore to go for the single coated 6-stop B+W filter. Link to post Share on other sites More sharing options...
Paul J Posted April 28, 2013 Share #9 Â Posted April 28, 2013 I would go for the multi coated, personally. At first, actually, I found cleaning the MRC an issue and then found a 'lenspen' cuts through the haze that you see on the filter instantly so it's not a problem at all. I've not compared the two filters but would imagine the MRC is a step up in terms of flare resistance and colour. Â In terms of letting more light through, well...6 stop reduction is 6 stop. You can't have more light and still lose 6 stops. Perhaps they mean it's a bit more than 6 because of the coating? I've not noticed that. Â I actually like the colour cast created. It's a very nice tone. Â In over cast lighting you will find your shutter speeds a bit low with the 6 stop. It's useful in full sun though. Especially with flash. A 3 stop gives you much more usability in less than full sun and you get to take advantage of 1/4000th shutter speed. Link to post Share on other sites More sharing options...
kdriceman Posted April 28, 2013 Share #10  Posted April 28, 2013 I'm mainly in The Netherlands and Sweden so weather-wise it'd be similar to the UK, I guess. I also read that 6-stop filters have a warmer colour cast but I think I wouldn't mind that, actually. I've been thinking if 6 stops would be too much but I think it might be ok.  B+W has two versions of the 6-stop, single and MRC-coated. Reading around, it seems MRC filters 1) are easier to clean due to the increased resistance, and 2) let more light through. Easier to clean is a good thing, but not really super necessary I would think. To let more light through seems to contradict the purpose of an ND filter.  My current thinking is therefore to go for the single coated 6-stop B+W filter.  I have one of each and find occasion to use both fairly often. I decided that since I have something like $10,000 in lenses a few more $$'s to have the filter I want is worth it. I also buy the MRC filters because I have had some issues with unwanted filter glare/reflection and I believe MRC is expected to help that. Again a few $$'s more, but it seems if I'm spending this kind of time and money on camera, lens, film, post processing, a little more on filters might help some of those images be better. Link to post Share on other sites More sharing options...
philipus Posted April 29, 2013 Author Share #11 Â Posted April 29, 2013 In over cast lighting you will find your shutter speeds a bit low with the 6 stop. It's useful in full sun though. Especially with flash. A 3 stop gives you much more usability in less than full sun and you get to take advantage of 1/4000th shutter speed. Â Thanks Paul. You raise several very good points. Since i only use film I'm limited to 1/1000. But since I usually shoot ISO400, even on an overcast f5.6 day I could shoot at about 1/60. That was my thinking behind choosing the 6-stop. It would work well with my Summiluxes but of course less so with the 90 Elmarit-M. So a 6-stop might after all be somewhat limiting. Hmm decisions decisions. Link to post Share on other sites More sharing options...
Guest tanks Posted April 29, 2013 Share #12 Â Posted April 29, 2013 Also, if you are using B&W film along with color filters you will lose a stop as well, depending on the filter. something else to consider. Link to post Share on other sites More sharing options...
philipus Posted April 29, 2013 Author Share #13 Â Posted April 29, 2013 Thanks tanks. The only other filter I use is a UV haze filter. Link to post Share on other sites More sharing options...
